08-30-2016, 15:32 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2616651 Status: Offline Thanks Meter: 5 | Sam s7562 erro Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-S7562 Software version: 26.6 Reading phone info... Model: GT-S7562 Country code: ªU Cal date: ªU Factory SW: S7562XXALHB Unique number: CJJ032910454860 Memory phone: ªU Phone S/N: 0000000000 PDA/CSC version: S7562XXALHB/S7562DBTALH3 Phone version: SW VERSION :None Phone HW: None Cal date: none Reading IMEI... OK IMEI: 0 Waiting ADB device... OK Reading phone info... Model: GT-S7562 Android version: 4.0.4 Product code: Not Active Phone version: S7562XXLH5 PDA version: S7562XXALHB CSC version: S7562DBTALH3 CSC country code: Germany CSC sales code: DBT HW version: Not Acti Phone S/N: 00000000000 Modem board: RF cal date: NONE IMEI: Checking Super user right... false This model not supported for auto root Done with Samsung Tool PRO v.26.6 |
