Old 12-27-2013, 00:42   #16 (permalink)
Member: 1752663
Thanks Meter: 2
Originally Posted by flin18 View Post
This file can root me worked.
CF-Root Download
hi
did u try it with i747 on 4.3???
Old 12-27-2013, 06:36   #17 (permalink)
Member: 282766
Thanks Meter: 14
Cool i got it to work also!
ok for others that cant figure it out. if you have an att i747 s3 on 4.3 MJB bootloader and are getting the "Reading security... error access denied" when unlocking all you have to do is make sure your phone is rooted and has supersu installed with the KNOX security disabled ( it asks you when you run supersu for the first time if you want to disable it). then connect your phone to the z3x box ( i did usb cable not the 3300k cable) and like stated before you repair the imei using your imei from the back but make sure the repair network and repair efs setting are ticked. after it resets once and when it finishes the repair i manually rebooted again. afterwards i put my tmobile sim and boom it was unlocked!
i actually put a different imei just to make sure it worked the first time and then redid the imei repair with my correct imei, thats how i figure it out..
anyways thanks Z3X team!!!
The Following 2 Users Say Thank You to mr_kill_666 For This Useful Post:
Old 12-27-2013, 18:22   #18 (permalink)
Member: 2054981
Thanks Meter: 7
First *#7284# -> MODEM and in the same menu go Qualcomm USB Settings and choose DM + MODEM + ADB. Connect phone with UART Cable
in z3x use T999 ase model!
Selected model: I747
Selected port: COM9 Z3X Box Serial Port
Selected port speed: 115200
Reading phone info...
Build: M8960A-AAAANAZM-1.0.443030
Done with Samsung Tool v.16.3
Reading security... OK
Calculating... OK
Writing security... OK
Reseting...
Unlock done
Tested and works. (AT&T Device tested in germany with T-Mobile DE SIM)
Old 01-12-2014, 11:40   #19 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
Selected model: I747M
Selected port: COM94 SAMSUNG Mobile USB Serial Port
Build: M8960A-AAAANAZM-1.0.443100
Done with Samsung Tool v.16.8
Checking phone at COM94
Repairing IMEI... OK
Repairing network settings... OK
Reseting... OK
Repair done
I747M 4.3 UNLOCK IMEI REPAIR DONE
ROOT PHONE MANNUALLY FIRST.
B.R.
kalpesh varia
The Following 3 Users Say Thank You to PARMATMA For This Useful Post:
Old 01-15-2014, 03:51   #20 (permalink)
Crazy Poster
Member: 2013147
Thanks Meter: 2
ok guys here's what you have to do...
make sure the phone is rooted
first, dial *#7284#
set your phone to PDA
Second,
dial *#0808#
set your phone to dm+modem+adb
connect with USB, NOT UART !
go into samsung tool and set the model to T999
go into repair, repair the network and EFS, and change your IMEI
click ok, and let it do it's thing..
after it reboots the phone, it will show no network.
reboot manually after it is fully booted.
UNLOCKED !!!
Build: M8960A-AAAANAZM-1.0.443089
Selected model: T999
Selected port: COM51 SAMSUNG Mobile USB Serial Port
Searching ADB device...
Please, allow USB debugging on phone... OK
Model: SAMSUNG-SGH-I747
Android version: 4.3
Product code: SGH2I747MBBATT
Phone version: I747UCUEMJB
PDA version: I747UCUEMJB
CSC version: I747ATTEMJB
IMEI: ******059738125
Phone S/N: R31DB0ATNCP
Checking Super user right... true
Writing data to phone... OK
Rebooting phone... OK
Checking phone at COM51 OK
Reseting... OK
Repair done
The Following User Says Thank You to allisonmagic For This Useful Post:
Old 02-27-2014, 02:21   #21 (permalink)
Member: 2021716
Sonork: www.sonork.com
Thanks Meter: 2
Selected port: COM138 SAMSUNG Mobile USB Serial Port
Searching ADB device... OK
Model: SGH-I747M
Product code: Not Active
Phone version: I747MVLUEMK5
PDA version: I747MVLUEMK5
CSC version: I747MOYBEMK5
IMEI: Unknown
Phone S/N: R21CB2RAWPE
Backuping MMCBLK... OK
Checking phone at COM138
Backuping NVM... OK
Waiting phone... OK
Bypass MSL... OK
Repairing... OK
Restoring NVM... OK
Reseting... OK
Repair done
Done with Samsung Tool v.17.0
IMEI Done
Old 03-02-2014, 14:09   #22 (permalink)
Member: 881225
Sonork: 100.1678282
Thanks Meter: 80
Selected port: COM10 SAMSUNG Mobile USB Serial Port
Model: SGH-I747M
CSC version: I747MOYAEMK5
IMEI: Unknown
Phone S/N: 00000000000
Reseting EFS... OK
Waiting phone... OK
Bypass MSL... error
hepl plz
Old 03-04-2014, 08:05   #23 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
Model: SGH-I747M
IMEI: Unknown
Backuping NVM... OK
Waiting phone... OK
Bypass MSL... OK
Repairing... OK
Restoring NVM... OK
Reseting... OK
Repair done
IMEI Done
Ur imei now done can u tell me ?
Old 03-04-2014, 08:12   #24 (permalink)
Member: 337762
Sonork: 100.1581304
Thanks Meter: 50
how did u root this fone succefully i cant seem to get fone rooted allway say super has stop working
Old 03-04-2014, 09:43   #25 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
Update via wifi...
Sent from my GT-I9100 using Tapatalk
Old 03-06-2014, 06:39   #26 (permalink)
javeed_mp's Avatar
Member: 1166187
Sonork: 100.1616368
Thanks Meter: 168
update supersu from playstore
Old 03-06-2014, 21:49   #27 (permalink)
Member: 2021716
Thanks Meter: 2
I747
Yes man done and all is ok
Old 03-07-2014, 03:47   #28 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
But my was not done with Z3x then I repaired in another tool.
Old 03-07-2014, 03:49   #29 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
I am confused everything was same in my situation I hv already tried with 17.0 & 17.1 then why I got problem in repairing Imei.
Old 03-07-2014, 17:36   #30 (permalink)
Member: 1974488
Thanks Meter: 5
i have problem with security applacation to install super user
Page generated in 0.32292 seconds with 9 queries
