02-20-2014, 12:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2013 Location: India
Member: 2028547 Status: Offline Thanks Meter: 3 | how to erase flash s5253..... urgent .... i flashed s 5253 include bootfiles with multiloader..... but now ... phone shows .... rsrc1 must be rebuild.... if i need to erase flasg and write again ., how to erase it... pl., help... thanks .,, BR., |
02-20-2014, 13:54 | #4 (permalink) | |
Member: 2028547 Status: Offline Thanks Meter: 3 | Quote:
thanks brother., but i flash 2 times with 2 diffrent files both z3x and multiloader., but ..while flashing comleted .... phone shows.., same rsrc1 must be rebuild.. | |
02-20-2014, 14:31 | #5 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | Reflash with multiloader without boot Put you phone into Download Mode ( Press Volume DOWN + Camera key and Power Button ). Run Samsung Multiloader Select BRCM2133 Now you have too select these files each one in his field: Apps, Rsrc1, Rsec2 (use low), Factory FS, ShpApp, CSC, Fota. Press on Port Search button to check good connection with phone. Click on Download button to start updating your phone. Do Not touch or remove cable from the phone till the operation finished. After it done the phone will restart by itself. Do Full reset: *2767*3855# and it is Done. |
02-20-2014, 15:13 | #6 (permalink) | |
thank you brother ... i try it and post d reply.... but when i connect the cable ,phone goes automatetically download mode., and also now switch on the phone shows only download mode.... | |
02-20-2014, 16:01 | #8 (permalink) |
Member: 1522958 Status: Offline Thanks Meter: 24 | ech to much problems just reflash with kies 1 enter download model 2 run kies 3 enter tools>firmware upgrade and installation 4 enter model : GT-S5253 5 enter serial number its located on sticker under the battery 6 follow kies instruction 7 your prob will be solved good luck bro |
