08-03-2016, 19:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: SCN Movil Centro
Member: 321176 Status: Offline Sonork: 100.1640958 Thanks Meter: 62 | galaxy s5 G900T 6.0.1 unlocked but still lock Operation: Unlock Selected model: SM-G900T Selected port: COM566 SAMSUNG Mobile USB Serial Port Software version: 26.2 Reading phone info... Reading IMEI... OK IMEI: 353300061****** Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.2 Regards in advance. |
08-03-2016, 19:22 | #2 (permalink) |
Freak Poster Join Date: Jan 2009 Location: USA
Member: 945085 Status: Offline Thanks Meter: 70 | flash this modem with odin, and try to unlock again it should work. https://www.androidfilehost.com/?fid=24391638059059508 |
The Following 3 Users Say Thank You to toutanje For This Useful Post: |
08-03-2016, 20:09 | #3 (permalink) | |
Member: 321176 Status: Offline Sonork: 100.1640958 Thanks Meter: 62 | Quote:
I think is a new security ok 6.0.1 ????. Regards bedel. Last edited by bedel; 08-03-2016 at 20:17. | |
08-06-2016, 15:51 | #8 (permalink) | |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Quote:
Operation: Unlock Selected model: SM-G900T Selected port: COM116 SAMSUNG Mobile USB Serial Port Software version: 26.3 Reading phone info... Reading IMEI... OK IMEI: 351881060xxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.3 I downgrad @toutanje link file set hang on Tmobile logo i connect Z3X Box and unlock same Tmobile logo hand condition Then flash with 6.01 firmware again and set complete on and unlock . | |
08-06-2016, 17:58 | #9 (permalink) |
Member: 945085 Status: Offline Thanks Meter: 70 | I did one the other day, I just downgraded whole firmware and it worked for me. https://www.androidfilehost.com/?fid=24545065934258544 After you flash firmware from above, phone will hang on the tmobile logo. Turn phone off, boot into recovery and perform hard reset/factory wipe. Boot phone back up and it will boot up normal now and not hang. After that, proceed to do your tasks with z3x. |
The Following 2 Users Say Thank You to toutanje For This Useful Post: |
08-26-2016, 23:04 | #12 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2105654 Status: Offline Thanks Meter: 7 | g900t 6.0.1 pg2 G900TUVS1GPG2 Android version: 6.0.1 downgrade to 5.1.1 G900TUVS1FOL1 IT WORKS ...! ! ! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRY IT ON YOUR OWN RISK......... UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900T Selected port: COM134 SAMSUNG Mobile USB Serial Port Software version: 26.5 Reading phone info... Reading IMEI... OK IMEI: 3XXXXXXXXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.5 Last edited by George305JD; 08-26-2016 at 23:11. |
09-14-2016, 09:45 | #15 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Romania Age: 50
Member: 62032 Status: Offline Sonork: 1582666 Thanks Meter: 193 | i downgrade to 4.4.4 (4 files) https://www.androidfilehost.com/?fid=24421527759886335, after unlock then upgrade to 6.0.1 Success! |
