samsung j110h read code success but still locked UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J110H Software version: 23.8 Searching Samsung modem... detected COM88 Reading phone info... OK Model: SM-J110H Version: J110HXXU0AOGA/J110HOJV0AOGB/J110HXXU0AOGA/J110HXXU0AOGA Product code: SM-J110HZKDKSA Phone S/N: R51GA2WGF2L Imei: 355254073221784 Unique number: C4G01F9AB0E3B92 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:05) Freeze code: 97485946 NET lock: 17305935 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.8 |
try this coad after unlock PUK - 12345678 PIN - 00000000 |
no brother when i apply net lock code.. <<network unlock request unsuccessful>> |
try with a unlock sim.............u will be done |
finally success with unlock method UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SM-J110H/DS Software version: 23.8 Waiting ADB device... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZKDKSA Phone version: J110HXXU0AOGA PDA version: J110HXXU0AOGA CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone S/N: R51GA2WGF2L Modem board: SC7727S RF cal date: 20151023 IMEI: 355254073221784 Checking Super user right... true Running zTool, please wait... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.8 |
sir, what root file did you used for this unit? please share |
use pre rooted firmware download from support or tsar J110HXXU0AOGA_Pre_Rooted_System_v4.4.4 |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SM-J110H Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZKDKSA Phone version: J110HXXU0AOGA PDA version: J110HXXU0AOGA CSC version: J110HOJV0AOGB CSC country code: KSA CSC sales code: KSA HW version: MP 0.400 Phone S/N: R51GB2S8EEH Modem board: SC7727S RF cal date: 20151127 IMEI: 356402072766346 Checking Super user right... true Running zTool, please wait... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.2 |
i have a same problem with j110h/ds .unlock wih z3x unlock done but stil locked. UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SM-J110H/DS Software version: 24.9 Searching Samsung modem... detected COM47 Reading phone info... OK Model: Version: Product code: Phone S/N: Imei: Unique number: Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.9 |
try to read code networkunlock request unsuccsesful.try unlock sim emergency call onl UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J110H/DS Software version: 24.9 Searching Samsung modem... detected COM47 Reading phone info... OK Model: Version: Product code: Phone S/N: Imei: Unique number: Reading codes... OK Please wait, calculating codes... OK (time - 00:00:18) Freeze code: 12345678 NET lock: 11111111 Sub lock: 11111111 SP lock: 11111111 CP lock: 11111111 For check lock status: *#7465625# Done with Samsung Tool PRO v.24.9 |
please help ........ |
Try to root then try Sent from my iPhone using Tapatalk |
thank for replay .i allready tride with rooted firmware but same problem .unlock done but still locked |
