Old 01-27-2017, 11:25   #1 (permalink)
Member: 248056
Sonork: 100.1605008
Thanks Meter: 11
Lg h831 unlock problem
LG H831 G5
not detected in normal mode all driver ok and all sitting done . in download mode no problem
H83120A ANDROID 7
Old 01-27-2017, 12:04   #2 (permalink)
Member: 2368022
Thanks Meter: 75
u use octppus latest version
Remove SD and SIM cards from the phone;
Connect powered-on phone to PC with Micro USB Type-C cable;
Install necessary driver;
Click "Unlock" button;
Follow software instructions (prompts).
Note: To connect the phone in Normal Mode, do one of the following:
Enable "USB Debugging" mode;
Type 277634#*# or *#546368#*831# or 3845*#831#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled".
Old 01-27-2017, 13:20   #3 (permalink)
Member: 248056
Sonork: 100.1605008
Thanks Meter: 11
i did all the steps and nothing
this help file from octopus
Old 01-28-2017, 18:44   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Connect in Charge only or MTP mode.
Old 01-31-2017, 09:00   #5 (permalink)
Member: 1495936
Sonork: none
Thanks Meter: 5
just use z3x latest update of lg tools that what i used to unlock this model..
Page generated in 0.13418 seconds with 8 queries
