fokal2008 | 07-01-2022 17:25 | samsung j810f frp reset done [Done] J810F FRP DONE Code:
UNLOCK INSTRUCTIONS:
Reading codes using sever:
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select device in ADB settings.
6. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Reset FRP
Selected model: SM-J810F
Software version: 44.11
Searching Samsung modem... detected COM28
Reading phone info... Model: SM-J810F
AP version: J810FJXS5CUD1
CSC version: J810FOXM5CUD1
CP version: J810FXXS5CUD1
OS version: 10
Product code: SEK
Phone SN: R58K75LFCNB
IMEI: 359123092139333
IMEI2: 359124092139331
Unique number: CRH002597903E65
Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK
Executing 1st step... OK
Waiting ADB device... OK
Executing 2nd step... OK
Rebooting phone... OK
For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.44.11 [SM-J810F,Reset FRP] https://i.postimg.cc/ht1r2B94/j810f-frp-ok.png |
