07-25-2017, 06:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | Root & Unlock J700T last version J700TUVU3AQC3 Operation: Unlock Selected model: SM-J700T Software version: 28.9 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J700T Android version: 6.0.1 Product code: SM2J700TZWATMB Phone version: J700TUVU3AQC3 PDA version: J700TUVU3AQC3 CSC version: J700TTMB3AQC3 CSC country code: USA CSC sales code: TMB HW version: REV0.5 Phone SN: R58J509XRJJ Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20170504 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: AC 6D C1 09 12 B5 77 B8 6C 56 44 DF 0B 21 B5 55 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.9 |
07-26-2017, 11:26 | #2 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: KOSOVA Age: 37
Member: 20566 Status: Offline Thanks Meter: 29 | How did you root the phone ?? Quote:
The Following User Says Thank You to GazI For This Useful Post: |
07-28-2017, 19:24 | #5 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | I just did one with AQC3 using these files, worked fine. Use the TWRP on this post, not off TWRP website https://forum.xda-developers.com/gal...0t-t1-t3560342 |
07-29-2017, 01:07 | #6 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2447870 Status: Offline Thanks Meter: 0 | Root doesnt work on AQC3 i tried for multiple twrp and even then one from the xda developers nothing works. I flash twrp then wait till finished take out battery volume up home and power and it turns on but never lets me access the twrp recovery i just flashed. Doesnt work on new security unless the phone on working on is a special j700t |
07-29-2017, 01:11 | #7 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | Not sure why. I tried multiple TWRP versions and they didn't work, , but this one worked on AQC3. I didn't battery pull. Once TWRP flashed,hold down Vol- and power. After screen goes black, switch to Vol+ - Home - Power |
07-30-2017, 00:53 | #9 (permalink) |
Member: 2277857 Status: Offline Thanks Meter: 68 | 1) Flashed the version of TWRP from the link above (that's the only one that worked) 2) Boot into TWRP after flash as explained above 3) flash SuperSU in TWRP 4) Run Unlock in Z3X 5) Flash factory AQC2 if you can't boot to TWRP, flash it again and retry |
07-30-2017, 05:49 | #11 (permalink) |
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | |
08-01-2017, 01:24 | #13 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | let try ur own risk here https://mega.nz/#!IENBwaqJ!xgWBvz9xR...eF6FKT7ksS0Mv4 |
