02-20-2022, 15:11 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: yemen
Member: 884054 Status: Offline Thanks Meter: 27 | sm-g960u unlock at&t [Answered] UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server' or press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960U Software version: 43.25 Checking Login and Password... OK Balance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting for device to become ready... OK Reading phone info... Model: SM-G960U Android version: 10 PDA version: G960USQS9FUB1 CSC version: G960UOYN9FUB1 Phone version: G960USQS9FUB1 Product code: SM-G960UZKAAIO CSC country code: USA CSC sales code: AIO Carrier ID: AIO Phone SN: 3636463255313498 IMEI: 353301090963500 HW version: REV1.1 RF cal date: 2019.01.16 Chip name: SDM845 Modem board: SDM845 Security patch: 2021-02-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung diag port... detected COM265 Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM25 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... no answer from server what's problem ? |
