06-19-2018, 11:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Samsung S6 Edge Docomo Unlock Error SC-04G Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SC-04G Selected port: COM9 SAMSUNG Mobile USB Serial Port Software version: 32.7 Reading phone info... Reading IMEI... OK IMEI: 357569060296806 Unlocking... error (02) Done with Samsung Tool PRO v.32.7 |
06-20-2018, 16:22 | #4 (permalink) |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Sorry I don't See any Combination Files any place for this Model !!! also this Model Unlock via DIAG Port . So Combination File not help . I Have Successfully Unlocked by Following Steps
08-07-2018, 14:04 | #7 (permalink) | ||
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,791 | Quote:
08-07-2018, 14:43 | #9 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
If *#0808# doesn't do anything, you can try using a shortcut app like QuickShortcuts or ShortMaster and search for "Util" or "Diag", then try all those activities till you find the correct one. Sometimes if the CSC didn't flash properly, that could also cause keyboard diag commands to fail, so try reflashing it with full stock first then the combi. | |
08-07-2018, 15:38 | #11 (permalink) | |
08-13-2018, 13:36 | #14 (permalink) | |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
* Root Your Phone & Do Enable Diag via Z3X . Now You Can Enable DIAG via *#0808# or *#9090# Br Real ASH GSM Helper | |
08-13-2018, 14:04 | #15 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,364 | samsung galaxy SC-04G UNLOCK DONE AFTER WRITE THIS MODEM FILE samsung galaxy SC-04G UNLOCK DONE AFTER WRITE THIS MODEM FILE DOWNLOAD HERE MODEM FILE WRITE MODEM FILE UNLOCK DONE |
The Following 7 Users Say Thank You to pintu_das For This Useful Post: |
