Yash_npj | 10-26-2017 15:00 | Samsung SCV35 Read Codes Via Server ok, unlock failed. Z3x team please see logs: Code:
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SCV35
Selected port: COM1 Communications Port
Software version: 29.5
Checking Login and Password... OK
Ballance: 45 crd.
Waiting ADB device... OK
Reading phone info...
Model: SCV35
Android version: 7.0
Product code: SM-G955JZSAKDI
Phone version: SCV35KDU1AQF2
PDA version: SCV35KDU1AQF2
CSC version: SCV35KDI1AQF2
CSC country code: JP
CSC sales code: KDI
HW version: REV08
Phone SN: R58J5629DHY
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-06-01
RF cal date: 2017.05.26
IMEI: 356380080802016
Rebooting phone... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM25 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 68529170
NET lock: 00000000
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.29.5 How to unlock This model, if not then how can i get my credit back. User: zsc_DRp8KQUC
WBR
Yash_npj |
