04-23-2021, 04:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | samsung SGH-A847M while unlocking giving error [Answered] Code: UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A847M Selected port: COM10 Qualcomm HS-USB Diagnostics 9002 Software version: 42.10 Reading phone info... OK Model: SGH-A847M Country code: ij³ª´Ù/BMC Cal date: 2010-11-19 Factory SW: BMJK4 Unique number: 55180001919937 Memory phone: K5R2G1GACE(A847)S Phone SN: R21C64AZHF Reading IMEI... OK IMEI: 355830042000274 Reading software version... OK Phone version: A847BMJK4 Searching sysinfo... not found Done with Samsung Tool PRO v.42.10 |
04-25-2021, 23:37 | #5 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | Hi here photo of the phone with simcard it show phone freez When I entered freez code it show fail to deactivate freez image-2021-04-24-12:37:19-308.jpg |
04-26-2021, 22:55 | #7 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
Code: UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A847M Selected port: COM10 Qualcomm HS-USB Diagnostics 9002 Software version: 42.10 Reading phone info... OK Model: SGH-A847M Country code: ij³ª´Ù/BMC Cal date: 2010-11-19 Factory SW: BMJK4 Unique number: 55180001919937 Memory phone: K5R2G1GACE(A847)S Phone SN: R21C64AZHF Reading IMEI... OK IMEI: 355830042000274 Reading software version... OK Phone version: A847BMJK4 Searching sysinfo... not found Done with Samsung Tool PRO v.42.10 | |
04-27-2021, 07:47 | #8 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,056 | Quote:
04-27-2021, 23:22 | #9 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | Hello with 19.1 also give error here is the log Code: Selected model: A847 Selected port: COM10 Qualcomm HS-USB Diagnostics 9002 Selected port speed: 115200 Reading phone info... OK Model: SGH-A847M Country code: ij³ª´Ù/BMC Cal date: 2010-11-19 Factory SW: BMJK4 Unique number: 55180001919937 Memory phone: K5R2G1GACE(A847)S Phone S/N: R21C64AZHF Reading IMEI... OK IMEI: 355830042000274 Build: SBAM6290A-KPVMZL-2.6.014023_1S Reading phone version... OK Phone version: A847BMJK4 Searching sysinfo... error Done with Samsung Tool v.19.1 Code: Platform: Samsung Anycall Selected port: COM10 Selected model: SGH-A847M Mode: Normal Phone model: SGH-A847 Warning: Selected model (SGH-A847M) differs from the detected one (SGH-A847)! Firmware compiled date: Aug 12 2010 Firmware compiled time: 07:00:00 Firmware released date: Nov 18 2010 Firmware released time: 21:31:01 Phone IMEI: 355830-04-200027-4 Bluetooth MAC: D7:DB:D1:5D:71:0C SW version: SBAM6290A-KPVMZL-2.6.014023_1S Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 73683148 NCK unlock code: 51713926 NSCK unlock code: 00000000 SPCK unlock code: 00000000 CPCK unlock code: 00000000 Work time: 0:00:20 |
