Samsung SGH-M919 Galaxy S4 T-Mobile Unlock Done Samsung SGH-M919 Galaxy S4 T-Mobile Unlock Done with Z3x Box Operation LOgs: ============= Code: Selected model: M919 Requirements : =========== 1-C3300K cable (UART Cable) 2-Z3x Box (Sure) :D 3- Samsung Tool (at least v14.4) Important Note : ============= You don't need ROOTING your device OR Enable USB DEBUGGING. Instructions: ========== 1- Press *#7284# and select "MODEM". 2- Press *#9090# and select " DM OVER UART". after that Phone will be Restarted ! 3- Choose Box Com port in Port filed. 4- Press Read Codes / Unlock. 5- Enjoy ;). |
thank you nang |
thanks bro, let me check |
super solution thank U BOSS |
i need you help !! for SGH-M919 emergency mode First dial *#0808# and select: DM - MODEM - ADB , its ok i select then *#9090# select: DM OVER UART[*] dont work i see in black all and no detect the phone Selected model: M919 Selected port: Selected port speed: 115200 Port not selected Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM7 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM9 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 |
I have the same issue. Why is there no solution to this black Service Mode? |
dial *#0808# select RNDIS+DM+MODEM click ok connect phone to USB cable. Select Samsung USB port and click Unlock. Tested on 50+ units. if still doesnt connect flash stock rom and try again. for USB connection *#9090# should be selected to DM/UM over HSIC |
successfully unlock Samsung S4 M919 By Z3x :):):) Selected model: M919 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.1 |
Selected model: M919 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 |
hvae u any sloution unlock 4.3 ver:confused::confused::confused::confused: |
tnx a lot mate i just unlocked my s4..tnx a lot for shearing :D |
Selected model: M919 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.16.8 Selected model: M919 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*29393942# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 thanks bro |
i get this error Code: Selected model: M919 |
