GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Z3X-Team Products (https://forum.gsmhosting.com/vbb/f453/)
-   -   samsung sm-A115U is supported to unlock [Answered] (https://forum.gsmhosting.com/vbb/f453/samsung-sm-a115u-supported-unlock-answered-2929766/)
atou 12-02-2020 20:40
UNLOCK INSTRUCTIONS:
To unlock using sever:
Knox warranty does not matter.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information'
to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Info
Selected model: SM-A115U
Software version: 41.8
Searching Samsung modem... detected COM14
Reading phone info...
Model: SM-A115U
AP version: A115USQU2ATG2
CSC version: A115UOYN2ATG2
CP version: A115USQU2ATG2
Product code: TMK
Phone SN: R95N60CPTWR
IMEI: 355357
Unique number: H1551443037BD8D31967
Reading IMEI... OK
IMEI: 35535
Done with Samsung Tool PRO v.41.8
NETROPPC
Z3X 12-02-2020 21:14
Hello. Currently supported only sprint for unlocking. You have t-mobile locked phone.
atou 12-02-2020 21:21
Originally Posted by z3x (Post 14278789)
hello. Currently supported only sprint for unlocking. You have t-mobile locked phone.
it is metropcc
thx
Z3X 12-02-2020 21:48
They have same lock type.
danoph83 12-19-2020 05:11
Can z3x unlock Sprint A115u with that same software and bit version as posted above?
Z3X 12-19-2020 08:34
Hello, yes. Supported models and firmwares you can always check here: https://z3x-team.com/check-your-phone/
Page generated in 0.08863 seconds with 6 queries
