10-06-2018, 10:30 | #65 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | no bro tried to reset frp in download mode now phone stuck on logo flashed with this firmware G930FXXU2ERGE_G930FUWE2ERG3_CWW but now only battery charging logo only going to download mode now i need tested stock room to revive my phone |
10-06-2018, 14:46 | #68 (permalink) | |
Member: 2478233 Status: Offline Thanks Meter: 596 | frp removed done Quote:
Operation: Reset FRP UFS Selected model: SM-G930F Selected port: COM6 USB Serial Port Software version: 33.8 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM6 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G930F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.33.8 big thanks bro frp removed flashed with your given files after that removed frp through z3x uart ufs | |
01-02-2019, 18:33 | #70 (permalink) |
Junior Member Join Date: May 2017
Member: 2716093 Status: Offline Thanks Meter: 2 | G930F FRP Remove Doesn't work by Z3X Hello, everytime I try to remove frp (ufs) I'm getting a "frp removed" message in z3x but when the phone restarted it's still "locked". I tried to flash a lower version (afaik the phone has the last december patch installed) but it's still the same (z3x says successfully done but it's still locked). If I try to flash a combination rom either: FA60_G930FXXU2ARA2 or FA60_G930FXXU1APB4 I'm getting an error in z3x with sboot. The device shows an error with binray and device (dunno exactly right now). Anyone can help me out with this problem? z3x Is up to date. Thanks in advance |
01-02-2019, 18:59 | #71 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | DD U TRY WITH COMBINATION AND TRY DO FRP BY UFS AND T FAILED?? GIVE IT A TRY IF FAILS FLASH FULL COMBINATION THEN FLASH STOCK FIRMWARE EXCLUDING CSC(Cache and metadata and pit) |
01-02-2019, 19:25 | #72 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Join Date: May 2017 Posts: 1 Obviosly u get error when write u1 combination over u2 or u3 software. UFS FRP works only on Android 7, u1&2. Write proper combi then stock software, only BL+AP. BR, |
01-03-2019, 09:09 | #75 (permalink) | |||
Member: 2716093 Status: Offline Thanks Meter: 2 | Quote:
but the file got removed. Anyone able to upload it again? | |||
