Old 12-30-2017, 07:45   #1 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
samsung SM- j701f frp reset done Security patch: 2017-11-01
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Reset FRP
Selected model: SM-J700F
Software version: 30.2.2
Waiting ADB device... OK
Reading phone info...
Model: SM-J701F
Android version: 7.0
Product code: SM-J701FZDDINS
Phone version: J701FXXU2AQK2
PDA version: J701FDDU2AQK2
CSC version: J701FODD2AQK2
CSC country code: India
CSC sales code: INS
HW version: MP 0.400
Phone SN: RZ8JA21SCAM
Chip name: EXYNOS7870
Modem board: SHANNON315
RF cal date: 20171028
IMEI: 353632092708851
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.30.2.2
The Following User Says Thank You to sachu2002 For This Useful Post:
Old 03-13-2018, 08:49   #2 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 238
time loss solution boss not success >>>>post some easy way
Old 04-30-2018, 11:16   #3 (permalink)
Pragyan_Gehlot's Avatar
Member: 503334
Sonork: 100.1590885
Thanks Meter: 173
https://www.youtube.com/watch?v=kI2Y...ture=*********
Page generated in 0.14474 seconds with 9 queries
