10-07-2016, 10:09 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Georgia in Gori Age: 34
Member: 2188828 Status: Offline Sonork: WOW Thanks Meter: 66 | Samsung T377A unlock [done] Selected model: SM-T3777 Software version: 26.9 Searching Samsung modem... detected COM40 Reading phone info... OK Model: SM-T377A AP version: T377AUCU1APF1 CSC version: T377AATT1APF1 CP version: T377AUCU1APF1 Product code: SM-T377AZKAATT Phone SN: R52H705C26Z Unique number: CAJ030A0EF0CB53 Reading IMEI... OK IMEI: 353608072208880 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
The Following 3 Users Say Thank You to zangoako For This Useful Post: |
01-03-2017, 12:30 | #2 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-T3777 Software version: 27.6 Searching Samsung modem... detected COM188 Reading phone info... Ok Model: SM-T377A AP version: T377AUCU2APJ2 CSC version: T377AATT2APJ2 CP version: T377AUCU2APJ2 Product code: SM-T377AZKAATT Phone SN: R52H910NFFY Unique number: CAJ033406B49B93 Reading IMEI... Ok IMEI: 353608073450267 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 8D 63 82 05 EC A2 70 79 82 59 4D 2B B5 54 67 70 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:13) Freeze code: 16257595 NET lock: 97075825 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.6 |
03-16-2017, 03:22 | #3 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1204194 Status: Offline Thanks Meter: 5 | how i can remove the att numbersync from this tablet icant use it like phone because of this function, there is a way to disable it or remove it? thanx its a t377a att 6.0.1 |
The Following 2 Users Say Thank You to xxkrakunxx For This Useful Post: |
08-19-2017, 21:57 | #9 (permalink) |
Junior Member Join Date: Jul 2006
Member: 320662 Status: Offline Thanks Meter: 4,294,967,295 | Cannot find SM-T377A Hi there everyone, I am trying to find a solution to my problem, i got the 29.1 installed but i dont see the SM-T377A model, i can see the SM-T377 /7 /P /T /V /W variants but not the /A, any clue? I would really appreciate the help. ps: i understand clearly he said 26.9 but i cannot find it anywhere and i think 29.1 should have everything..... no? |
08-23-2017, 08:53 | #10 (permalink) | |
Member: 2188828 Status: Offline Sonork: WOW Thanks Meter: 66 | Quote:
10-03-2017, 13:18 | #11 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Bangladesh Age: 34
Member: 2581716 Status: Offline Sonork: 30294069 Thanks Meter: 137 | Searching Samsung modem... detected COM118 Reading phone info... OK Model: SM-T377A AP version: T377AUCU1APF1 CSC version: T377AATT1APF1 CP version: T377AUCU1APF1 Product code: SM-T377AZKAATT Phone SN: R52H80G2LQP Unique number: CAJ036693EE0573 Reading IMEI... OK IMEI: 353608072896023 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool 29.4 |
The Following User Says Thank You to gsmanam For This Useful Post: |
01-04-2018, 09:18 | #12 (permalink) |
Crazy Poster Join Date: Apr 2014
Member: 2161862 Status: Offline Thanks Meter: 7 | error Searching Samsung modem... detected COM94 Reading phone info... OK Model: SM-T377A AP version: T377AUCU2APJ2 CSC version: T377AATT2APJ2 CP version: T377AUCU2APJ2 Product code: SM-T377AZKAATT Phone SN: R52J7036QLM Unique number: CAJ0351C9EEBE64 Reading IMEI... OK IMEI: 359768081745837 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.1 |
The Following User Says Thank You to mohitkhurana93 For This Useful Post: |
02-01-2018, 01:59 | #13 (permalink) | |
Insane Poster Join Date: Apr 2017 Location: Anaheim California
Member: 2710649 Status: Offline Thanks Meter: 47 | Unlock Done with Nougat update Quote:
02-21-2018, 23:26 | #14 (permalink) | |
Freak Poster Join Date: Jun 2015 Location: Eastern U.S.
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Quote:
Sincerely, The Cell Magicians | |
02-21-2018, 23:34 | #15 (permalink) | |
The Following 3 Users Say Thank You to CastleSamsung12 For This Useful Post: |
