Someone can answer me, A5 2017 ( A520F ) also support repair imei and patch cert ? |
good update mr blang:D |
samsung g532f reed code done without root samsung g532f reed code done without root Operation: Read Codes Selected model: SM-G532F Software version: 29.4 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDKSA Phone version: G532FXXU1AQB3 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RV8J715TA1V Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 RF cal date: 20170720 IMEI: 359614085945645 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM17 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:08) Freeze code: 41902794 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 61949481 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 :p;):p;):p;) |
Hello z3x team, in 29.4 have the bug in imei reparation of J700m. No signal after patch. |
sm g532f/m/g network unlock without root? |
what about FRP unlock? please add one click frp remove. |
Please I need sim unlock tools for j3-327p |
at this moment solution not exist. |
G532G Patch cert add now Sent from my iPhone using Tapatalk |
Ok sir Sent from my iPhone using Tapatalk |
UNLOCK INSTRUCTIONS: Direct unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To read security codes (without root permissions): 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes Selected model: SM-G532F Software version: 29.4 Please wait, generating hash codes file, this can take few minutes... OK Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZKDKSA Phone version: G532FXXU1AQG5 PDA version: G532FXWU1AQG5 CSC version: G532FOJV1AQG5 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: R58J7XXXXX Chip name: MT6737T Modem board: MT6737T Security patch: 2017-07-01 RF cal date: 20170709 IMEI: 359619XXXXXXX Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM15 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:07) Freeze code: 26136484 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 69164240 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
