sharif_tell I have the same problem, something solution ? |
unlock done but not unlocked, something solution ?? |
provide: 1. phone SN. 2. Logs. 3. Login |
hard reset, repeat unlock |
im still getting erros, and why is the N920T not supported for unlock via TMB ? it has the unlock app in it |
what happened to the repair imei tab. The repair option is there but no imei input option. |
thank.....................update |
Thanks for new update , want to see anothaer latest model |
add TWRP models samsung in support Z3X Shell |
The same problems with j327t1 hard reset , then unlock and phone still locked :( Checking Login and Password... Listo Ballance: 15 crd. You have 15 credit(s) left. This operation takes 10 credits.Continue? Si Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Leyendo información del teléfono ... Modelo: SM-J327T1 Android version: 7.0 Código del Producto: SM2J327TZKATMK Versión del telefono: J327T1UVU1AQCB PDA version: J327T1UVU1AQCB CSC version: J327T1TMK1AQCB Código de país CSC: USA Código de Venta CSC: TMK HW version: REV0.1 Phone SN: R28J6380SJA Chip name: EXYNOS7570 Módem: SHANNON305 Security patch: 2017-03-01 RF cal date: 20170627 IMEI: 35961708xxxxxx Searching Samsung diag port... detectado COM73 Leyendo información del teléfono ... Listo CP version: J327T1UVU1AQCB CP build: Mar 23 2017 16:54:01 Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.30.4 |
UNLOCK INSTRUCCIONES: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G935A Software version: 30.4 Checking Login and Password... Listo Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Si Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SAMSUNG-SM-G935A Android version: 6.0.1 Código del Producto: SM-G935TZSAATT Versión del telefono: G935AUCS4APK1 PDA version: G935AUCS4APK1 CSC version: G935AATT4APK1 Código de país CSC: USA Código de Venta CSC: ATT HW version: REV0.7 Phone SN: RF8H81Z16YX Chip name: MSM8996 Módem: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.08.18 IMEI: 35775107XXXXXXX Reiniciando teléfono ... Listo Waiting ADB device... Listo Reiniciando teléfono ... Listo Waiting ADB device... Listo Waiting for device to become ready... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM13 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 14168097 NET lock: 30596042 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.30.4 I put the Net Lock code and I give it Unlock, it comes out that if it releases it but in reality it does not release it, I always get an invalid Sim Card. Network lock, if you need a sample video I will send it to you to check. He has already made a hard reset and remains the same. |
