12-07-2016, 05:24 | #136 (permalink) |
Junior Member Join Date: Aug 2005 Location: CANADA Age: 40
Member: 166459 Status: Offline Thanks Meter: 9 | |
12-07-2016, 05:42 | #139 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Need help - sm-g920az 6.0.1 not supported cricket UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G920AZ Software version: 27.4 Searching Samsung modem... detected COM42 Reading phone info... Ok Model: SM-G920AZ AP version: G920AZTUS5CPG5 CSC version: G920AZAIO5CPG5 CP version: G920AZTUS5CPG5 Product code: SM2G920AZKZAIO Phone SN: R38G40DESSV Unique number: 03157DF3C1EB5522 Reading IMEI... Ok IMEI: 359702060144654 (SIGN: OK) Checking hash file... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.4 |
The Following User Says Thank You to creconinfo For This Useful Post: |
12-07-2016, 07:20 | #143 (permalink) |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | s7 g930f help need for unlock Operation: Read Codes Selected model: SM-G930F Software version: 27.4 Searching Samsung modem... detected COM328 Reading phone info... Ok Model: SM-G930F AP version: G930FXXS1BPI8 CSC version: G930FVFG1BPH2 CP version: G930FXXU1BPHJ Product code: SM-G930FZDAVOD Phone SN: R58H93X6VPT Unique number: CE09160961F2EC0203 Reading IMEI... error (0) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON335 HWID: 01 10 35 03 01 10 35 03 72 0F 35 A8 69 FA 46 20 Reading NV data... Ok Checking NV data... Ok Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.27.4 |
12-07-2016, 07:28 | #144 (permalink) | |
Insane Poster Join Date: Oct 2011 Location: iran.behbahan
Member: 1679748 Status: Offline Thanks Meter: 12 | Quote:
pls add G920F patch cert in new security xxx4 | |
12-07-2016, 08:16 | #146 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Chennai-India
Member: 1833113 Status: Offline Sonork: 100.1623537 Thanks Meter: 40 | read code not working Code: Operation: Read Codes Selected model: SM-G570F Software version: 27.4 Searching Samsung modem... detected COM222 Reading phone info... Ok Model: SM-G570F AP version: G570FXXU1APIB CSC version: G570FOJV1APIB CP version: G570FXXU1API9 Product code: SM-G570FZDDKSA Phone SN: R28HA0SMBMZ Unique number: CQ300C071DA2A93 Reading IMEI... Ok IMEI: 352948082199070 (SIGN: OK) IMEI 2: 352949082199078 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON305 HWID: 6A D7 EA 21 DB 15 6F 72 14 2A FD 43 0A 00 00 00 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:21) For check lock status: *#7465625# Done with Samsung Tool PRO v.27.4 |
12-07-2016, 08:42 | #148 (permalink) |
Junior Member Join Date: Oct 2009 Location: Calgary Canada
Member: 1150024 Status: Offline Thanks Meter: 0 | Operation: Unlock Selected model: SM-G920W8 Software version: 27.4 Searching Samsung modem... detected COM12 Reading phone info... Ok Model: SM-G920W8 AP version: G920W8VLU5CPI4 CSC version: G920W8OYA5CPI4 CP version: G920W8VLU5CPI4 Product code: SM-G920WZWABMC Phone SN: RF8G70Y16ZH Unique number: 06157DF665489417 Reading IMEI... Ok IMEI: 351559073040545 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.4 tried a few modems..none would allow ADB connect or show IMEI number Which modem to flash please? |
12-07-2016, 10:59 | #150 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Note 4 edge sm-n915w8 6.0.1 not supported for unlock NOTE 4 EDGE SM-N915W8 6.0.1 NOT SUPPORTED FOR UNLOCK UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N915W8 Selected port: COM48 SAMSUNG Mobile USB Serial Port Software version: 27.4 Reading phone info... Reading IMEI... Ok IMEI: 357223060120083 Unlocking... error (0) Done with Samsung Tool PRO v.27.4 |
