07-13-2017, 11:34 | #62 (permalink) | |
Freak Poster Join Date: Dec 2015 Location: New Zeland
Member: 2506735 Status: Offline Sonork: IT ZONE Thanks Meter: 20 | Same error on my side too, so have you find some solution for it plz kamal_singla Quote:
Same error on my side i try more then 5 mobiles j320ZN even on different opprating systems but still same, so have you got some luck or any solution ??? | |
07-13-2017, 15:44 | #66 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Or only original "U" phones which were not flashed from "A/T" to "U"? | |
07-13-2017, 15:46 | #67 (permalink) |
Junior Member Join Date: May 2010 Location: India
Member: 1300346 Status: Offline Thanks Meter: 39 | need help how to network unlock SM-A720F and where buy msl code Searching Samsung modem... detected COM12 Reading phone info... OK Model: SM-A720F AP version: A720FXXU1AQC5 CSC version: A720FOJV1AQC8 CP version: A720FXXU1AQC8 Product code: SM-A720FZDDKSA Phone SN: R58J4xxxxx Unique number: CBJ10EDF7xxxxxx Reading IMEI... OK IMEI: 3557580xxxxxxxx Reading SN... OK Phone SN: R58Jxxxxxx Enter MSL: canceled Operation aborted |
07-13-2017, 16:15 | #68 (permalink) |
Junior Member Join Date: Jan 2013 Location: freetown, sierraleone
Member: 1870105 Status: Offline Thanks Meter: 28 | I ENCOUNTERED SAME PPROBLEM UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G935A Selected port: COM132 SAMSUNG Mobile USB Serial Port Software version: 28.7 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G935A Android version: 6.0.1 Product code: SM-G935AZSAATT Phone version: G935AUCS4APK1 PDA version: G935AUCS4APK1 CSC version: G935AATT4APK1 CSC country code: USA CSC sales code: ATT HW version: REV0.7 Phone SN: R38H608R13V Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-11-01 RF cal date: 2016.06.08 IMEI: Initialization zTool... error (0) Done with Samsung Tool PRO v.28.7 ANY SOLUTION PLS |
07-13-2017, 18:46 | #71 (permalink) |
Freak Poster Join Date: Aug 2009 Location: bangladesh Age: 34
Member: 1104393 Status: Offline Sonork: 100.1603062 .::RONY::.. Thanks Meter: 130 | j3020zn samsung unlock success here the log Operation: Read Codes via Server Selected model: SM-J320ZN Selected port: COM49 SAMSUNG Mobile USB Serial Port Software version: 28.7 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J320ZN Android version: 5.1.1 Product code: SM-J320ZZDNXSA Phone version: J320ZNDOU1API1 PDA version: J320ZNDOS1AQC1 CSC version: J320ZNXSA1API2 CSC country code: Australia CSC sales code: XSA HW version: MP 0.200 Phone SN: R58HB380Z1D Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-03-01 RF cal date: 2016.11.16 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 74705964 NET lock: 74846079 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.7 tnx blang sir |
07-13-2017, 18:58 | #72 (permalink) | |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Quote:
