07-30-2017, 19:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-A520W unlock error after enter msl Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A520W Software version: 29.0 Searching Samsung modem... detected COM115 Reading phone info... OK Model: AP version: CSC version: CP version: Product code: Phone SN: Unique number: Reading IMEI... OK IMEI: 355xx70xxxxxxxxxx Reading SN... OK Phone SN: R58J32DSND Enter MSL: 5614093950340F0A322C24310159015D Bypass MSL... OK Unlocking... error Done with Samsung Tool PRO v.29.0 Last edited by ghacks; 07-30-2017 at 19:30. |
The Following User Says Thank You to ghacks For This Useful Post: |
