Old 11-20-2017, 08:17   #46 (permalink)
Crazy Poster
Member: 508890
z3x box First in the world ok
Old 11-20-2017, 08:20   #47 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 332
thanks for big update
but in our country we need imei repair patch cert
please time is working that
thank you
Old 11-20-2017, 08:20   #48 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
sir read codes diag done
but sir net lock not work
please solve it
Checking hash file... OK
Searching Samsung modem... detected COM428
Reading phone info... OK
Model: SM-A510FD
AP version: A510FXXU4CQG7
CSC version: A510FDOJP4CQG1
CP version: A510FDXXU4CQDL
Product code: MID
Phone SN: R58H82T3CPR
Unique number: C0000B335A96D43
Searching Samsung diag port... detected COM429
CP build: Apr 24 2017 17:53:49
Reading data from phone...
Reading NV data... OK
Modem board: SHANNON310
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:07)
Freeze code: 27952731
NET lock: 71728977
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.29.9
Old 11-20-2017, 08:22   #49 (permalink)
Member: 2493496
Thanks Meter: 57
after click read codes DIAG
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
To read security codes:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Read Codes DIAG
Selected model: SM-J710MN
Software version: 29.9
Exception: File access denied
Old 11-20-2017, 08:25   #50 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
please solve it
Model: SM-A510FD
Product code: MID
Calculating... OK
NET lock: 71728977
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
enter freeze code and then lock code.
The Following 4 Users Say Thank You to blang For This Useful Post:
Old 11-20-2017, 08:25   #51 (permalink)
nzsyl's Avatar
Member: 2752048
Thanks Meter: 58
biggest update in tha gsm world. we love z3x team products, love u lots, . many many thanks z3x team ,. only z3x is KIng of all gsm prducts,
Old 11-20-2017, 08:26   #52 (permalink)
Member: 2294376
Thanks Meter: 6
Kindly add model Samsung S727vl(GP)
sky pro for network unlock for the next update please
as of now we cannot unlock this unit
The Following User Says Thank You to Sir-Lester25 For This Useful Post:
Old 11-20-2017, 08:28   #53 (permalink)
Member: 2493496
Thanks Meter: 57
Searching Samsung modem... detected COM11
Model: SM-J710MN
AP version: J710MNUBU1API5
CSC version: J710MNUWE1API5
CP version: J710MNUBU1APG7
Product code: SM-J710MZWNBAT
Phone SN: RF8HC2K2L4M
Unique number: CAJ03F80C4D7AB3
Reading IMEI... OK
IMEI: 359587073316492 (SIGN: OK)
Done with Samsung Tool PRO v.29.9 help me mister blang
Old 11-20-2017, 08:29   #54 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
sir freeze code done
sir freeze code done but net lock not done
Old 11-20-2017, 08:31   #55 (permalink)
Member: 452497
Sonork: baig
Thanks Meter: 11
great update z3x team very usefull with out root read codes
Old 11-20-2017, 08:35   #56 (permalink)
Member: 1358967
Sonork: 100.1585102
Thanks Meter: 100
Selected model: SM-G610F
Searching Samsung modem... detected COM401
Model: SM-G610F
AP version: G610FDXU1BQH7
CSC version: G610FOLB1BQI2
CP version: G610FDDU1API9
Product code: XME
Phone SN: R58*******
Unique number: CBJ109489411D64
Searching Samsung diag port... detected COM400
CP build: Sep 19 2016 17:53:04
Modem board: SHANNON315
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 73174818
NET lock: 24291747
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
THANKS Z3X TEAM NO NEED ROOT NO NEED CREDIT
Old 11-20-2017, 08:44   #57 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
Originally Posted by loboloko68 View Post
excellent update, if credits cost 4, then when I have 5 and waste 4 , what do I do with the left credit¿ there are any way to recharge a credit account to the same user and password.
Originally Posted by alayne View Post
same question here....
I think both of you should buy 20 credits and try to unlock 5pcs. So simple
Old 11-20-2017, 08:56   #58 (permalink)
amirsaishi's Avatar
Member: 241938
Sonork: 100.1663699
Thanks Meter: 477
big update thanks,
please add security repair option for g920f etc..
Old 11-20-2017, 08:56   #59 (permalink)
aslam hossain's Avatar
Member: 2179298
Sonork: 100.1660353.Aslam
Thanks Meter: 215
Z3X-BOX Samsung PRO Update. Samsung Tool 29.9 Update. Read codes without server added
First in the world Z3X
(Read CERT DIAG)
if knox - 0. No root need.
Type *#0808# and select 'DM+ACM+ADB
Samsung Galaxy Note 8
successful Read cert Done
Searching Samsung modem... detected COM52
Model: SM-N950F
AP version: N950FXXU1AQI1
CSC version: N950FOXM1AQHF
CP version: N950FXXU1AQHB
Product code: XEU
Phone SN: R58J83JQYMF
Unique number: CE051715DDFA473C027E
Searching Samsung diag port... detected COM53
CP build: Aug 17 2017 17:41:21
Reading data from phone... OK
Calculating... OK
Certificate file saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\
backup\Cert\SM-N950F_R58J83XXXXX_35200XXXXXXXXXX_20-11-2017_13-22-3.cert
THANKS...........Z3X-Team Products.
The Following 3 Users Say Thank You to aslam hossain For This Useful Post:
Old 11-20-2017, 09:05   #60 (permalink)
Registered User
Member: 2443309
Thanks Meter: 14
The best in samsung field
The great will be be great for ever . Nice update.
Page generated in 0.26269 seconds with 9 queries
