02-19-2018, 21:44 | #61 (permalink) |
Freak Poster Join Date: Dec 2017
Member: 2787425 Status: Offline Thanks Meter: 26 | Mr.Blang ztool is buggy but worked Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 7.1.1 Product code: SM-N950UZKATMB Phone version: N950USQU1AQI5 PDA version: N950USQU1AQI5 CSC version: N950UOYN1AQI5 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J91CXE4Y Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-08-01 RF cal date: 2017.09.12 IMEI: 358 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... error (0.1) Retry 1... Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.8 |
The Following User Says Thank You to err0r_ For This Useful Post: |
02-25-2018, 11:00 | #64 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1915510 Status: Offline Thanks Meter: 19 | link download: https://www.youtube.com/watch?v=qWv_kaKokGo |
The Following User Says Thank You to nvda3 For This Useful Post: |
02-25-2018, 19:01 | #66 (permalink) |
Insane Poster Join Date: May 2012
Member: 1754209 Status: Offline Thanks Meter: 21 | Please Help UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G360T Software version: 30.8 Searching Samsung USB Flash interface... COM48 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.30.8 |
The Following User Says Thank You to Novardo For This Useful Post: |
02-26-2018, 21:57 | #69 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Germany
Member: 1690263 Status: Offline Thanks Meter: 85 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-G920F Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 Product code: Phone version: PDA version: G920FXXU5ERA5 CSC version: G920FDBT5EQL1 CSC country code: Germany CSC sales code: DBT HW version: Phone SN: R58G422B2EY Chip name: EXYNOS7420 Modem board: Security patch: 2018-01-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Reading data... error Security damaged (4 13) Done with Samsung Tool PRO v.30.8 where is the new uodate ?? |
02-27-2018, 15:34 | #70 (permalink) |
Member: 1690263 Status: Offline Thanks Meter: 85 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-G920F Software version: 30.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: PDA version: G920FXXU5DQA7 CSC version: G920FDBT5DQA3 CSC country code: Germany CSC sales code: DBT HW version: Phone SN: RF8G400640P Chip name: EXYNOS7420 Modem board: Security patch: 2017-01-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... error (0 6) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.5 help pls |
02-27-2018, 17:58 | #71 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2201155 Status: Offline Thanks Meter: 37 | j120w network unlock without root successfully with z3x 30.8 Operation: Unlock Selected model: SM-J120W Software version: 30.8 Searching Samsung modem... detected COM23 Reading phone info... OK Model: SM-J120W AP version: J120WVLU1APC8 CSC version: J120WOYA1APC8 CP version: J120WVLU1APC8 Product code: SM-J120WZKAXAC Phone SN: R58H33---- Unique number: CFN00BF9--- Reading IMEI... OK IMEI: 3571---07----95 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.8 |
02-27-2018, 18:03 | #72 (permalink) |
Member: 2201155 Status: Offline Thanks Meter: 37 | j120w efs and cert backup successfully with z3x 30.8 Operation: Read EFS Selected model: SM-J120W Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-J120W Android version: 6.0.1 Product code: SM-J120WZKAXAC Phone version: J120WVLU1APC8 PDA version: J120WVLU1APC8 CSC version: J120WOYA1APC8 CSC country code: Canada CSC sales code: XAC HW version: REV0.1 Phone SN: R58H3----- Modem board: SHANNON308 Security patch: 2016-04-02 RF cal date: 20160324 IMEI: 357116070------ Checking Super user right... true Reading EFS from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\EFS\EFS_SM-J120W_J120WVLU1APC8_3571---------_R58-----_27-2-2018_20-28-10.tar Done with Samsung Tool PRO v.30.8 ----------------------------- Operation: Read CERT Selected model: SM-J120W Software version: 30.8 Searching Samsung modem... detected COM23 Reading phone info... OK Model: SM-J120W AP version: J120WVLU1APC8 CSC version: J120WOYA1APC8 CP version: J120WVLU1APC8 Product code: SM-J120WZKAXAC Phone SN: R58H3-------- Unique number: CFN00BF99DABA23 Reading IMEI... OK IMEI: 35711607--- (SIGN: OK) Reading data from phone... OK Modem board: SHANNON308 HWID: 00 09 4B 1B 02 AD 31 23 18 C----- Reading NV data... OK Checking NV data... OK Calculating... OK Certificate file saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-J120W_R58H------_3571160----------_27-2-2018_20-32-25.cert Done with Samsung Tool PRO v.30.8 |
02-27-2018, 18:03 | #73 (permalink) |
