01-27-2021, 09:30 | #1 (permalink) |
Banned Join Date: Jan 2019 Location: tajikistan kulob
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 117 | how to unlock region samsung galaxy s20 ultra(SM-G988B/DS) by z3x box [Solved] Last edited by sunatullo4142; 01-27-2021 at 09:39. |
01-29-2021, 13:03 | #3 (permalink) | |
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 117 | Checking server answer... modem required Quote:
UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [Mar 2020] Selected model: SM-G988B Software version: 42.1 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G988B Android version: 10 PDA version: G988BXXU1ATCH CSC version: G988BOXM1ATCH Phone version: G988BXXU1ATCH Product code: SM-G988BZKDSER CSC country code: Russia CSC sales code: SER Carrier ID: DBT Phone SN: R3CMAxxxxx IMEI: 3518281xxxxxxx HW version: REV0.2A RF cal date: 20191105 Chip name: EXYNOS990 Modem board: SHANNON5123 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: REGIONAL_LOCKED,REGIONAL_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem required There is no information about this firmware on the server. Done with Samsung Tool PRO v.42.1 | |
01-29-2021, 13:17 | #5 (permalink) |
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 117 | UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-G988B Software version: 42.1 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G988B Android version: 10 PDA version: G988BXXU1ATCH CSC version: G988BOXM1ATCH Phone version: G988BXXU1ATCH Product code: SM-G988BZKDSER CSC country code: Russia CSC sales code: SER Carrier ID: DBT Phone SN: R3CMA03MGQT IMEI: 351828110074340 HW version: REV0.2A RF cal date: 20191105 Chip name: EXYNOS990 Modem board: SHANNON5123 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: REGIONAL_LOCKED,REGIONAL_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM31 Searching server... OK Checking server answer... modem required There is no information about this firmware on the server. Done with Samsung Tool PRO v.42.1 |
02-02-2021, 11:01 | #7 (permalink) | |
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 117 | Quote:
Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-G988B Software version: 42.1 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G988B Android version: 10 PDA version: G988BXXU1ATCH CSC version: G988BOXM1ATCH Phone version: G988BXXU1ATCH Product code: SM-G988BZKDSER CSC country code: Russia CSC sales code: SER Carrier ID: DBT Phone SN: R3CM IMEI: 35182811 HW version: REV0.2A RF cal date: 20191105 Chip name: EXYNOS990 Modem board: SHANNON5123 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: REGIONAL_LOCKED,REGIONAL_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM31 Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 72460 NET lock: 319 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.42.1 | |
The Following User Says Thank You to sunatullo4142 For This Useful Post: |
