08-14-2020, 18:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-J260AZ cannot unlock by z3x i flash modem combi stil same [Answered] Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-J260AZ Software version: 41.0 Checking Login and Password... OK Ballance: 19 crd. You have 19 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J260AZ Android version: 9 PDA version: J260AZTUS5BSK1 CSC version: J260AZAIO5BSK1 Phone version: J260AZTUS5BSK1 Product code: SM2J260AZKAAIO CSC country code: USA CSC sales code: AIO Phone SN: RF8M42EXWZB IMEI: 3562********* HW version: REV1.0 RF cal date: 20190418 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible or use new method. Done with Samsung Tool PRO v.41.0 |
08-17-2020, 07:28 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
try DIAG method. | |
