Old 08-13-2018, 07:07   #1 (permalink)
Member: 1706168
Sonork: 100.1619095
Thanks Meter: 66
Samsung Tool pro program damaged [Instruction step by step]
hello z3x team , I have problem with opening the samsung tool pro software it keeps saying program damaged, yesterday I have installed flexihub for another purposes but z3x did block my card, is there any way to fix the problem or I have to buy new smart card ? thanks in advance
Old 08-14-2018, 07:58   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
If you have problem - Program Damaged while running software.
1. Try clean SMARTCARD pins. Try use other reader for SMARTCARD. Try reinstall drivers. Try use other PC.
same problem then.
2. Disconnect all other boxes, dongles and try use function repair dead card:
- If function not allowed, remove smart card before goto window with repair dead card function
- then after сhoice repair, immediately put card back and do repair.
same problem then.
3. If BOX under warranty - ask reseller for replace.
4. If BOX not under warranty, and last time box using was not more than 6month, and you have damaged card in hands - buy empty card and we will replace activation to new card.
Just send email with SN old and new card: sales @z3x-team.com
The Following 16 Users Say Thank You to blang For This Useful Post:
Old 08-15-2018, 01:43   #3 (permalink)
Member: 1655844
Thanks Meter: 25
z3x programmed damaged!
Hi! i buy it Z3X full activated but 2 days later gave me this error "programmed damaged" when try it to fix whith shell not able to fix this, always show new shell available but not download anything, i downloaded latest shell from your website but show same error again and again, im very frustrated but 2 days later box is screwed and able to use again... thanks i need fix this
Old 08-31-2018, 11:41   #4 (permalink)
Member: 192296
Sonork: 100.1623059
Thanks Meter: 24
Program damaged
Gooday all of a sudden my z3x shows program damaged I've reinstalled software formatted pcs done everything possible still no success don't know if you can shift activation to other dongle coz I have another dongle not activated on Samsung pro and my present dongle has all activation pro, LG and some z3$ credit
Sent from my M6 using Tapatalk
Old 09-01-2018, 05:32   #5 (permalink)
Member: 757799
Thanks Meter: 782
Software always close
But in old software version ok
Old 09-01-2018, 08:27   #6 (permalink)
Member: 192296
Sonork: 100.1623059
Thanks Meter: 24
excellent help box now working thanks mr blang
Old 09-11-2018, 19:49   #7 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Sir need ur help,, I erroneously activated LG instead of Samsung Pro Activation now I need help in this regard to solve the issue customer is getting angry.
Box Seriel number is AADA7EC6.
Thanx n BR
Old 09-24-2018, 16:14   #8 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 45
Card problem ,....
some time my card not found .....
Old 09-24-2018, 16:16   #9 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 45
this is card detail...
plz help blang ,..//
Old 09-25-2018, 11:42   #10 (permalink)
Member: 2673772
Program damaged
Just repair dead card from shell and that's all...
The Following User Says Thank You to asadzian For This Useful Post:
Old 09-28-2018, 16:41   #11 (permalink)
Member: 805129
Thanks Meter: 191
Question Samsung Tool Pro Program Damaged What's the Problem With z3x
Hello z3x team,
I have a problem in a long time card remove with z3x box
Now two days ago a new problem start with my z3x
Program damaged����������
I have install new windows also change laptop to desktop pc
CARD change to another empty box but problem still same
Program damaged or Samsung toolpro suddenly close when software try to open.
Z3x shell show info ok also old setup 19.x open ok
Mr.Blang please help me I'm worry about it
Old 10-10-2018, 06:49   #12 (permalink)
Member: 1828619
Hello Z3x Team, pls I have this issue with my box I just activated it to pro 3 months ago but when ever I opened the pro I just see the ”Programme Damaged” I have try all what should be try to get it work but I still can’t makre it work either pls do I need to buy another box and give you the serial no so as to transfer the pro activation on it pls I don’t want to loose woefully. Thanks in advance.
Old 10-12-2018, 11:23   #13 (permalink)
sam3578's Avatar
Member: 540170
Thanks Meter: 101
any authorized reseller in the philippines where i can buy an empty card?
Old 10-14-2018, 06:19   #14 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 45
try bt no sucess ....
Old 10-21-2018, 18:10   #15 (permalink)
Member: 2754180
Z3x programm damaged
Hello z3x team,
Program damaged
Page generated in 0.25078 seconds with 9 queries
