04-19-2024, 10:09 | #1 (permalink) |
Junior Member Join Date: Feb 2017 Location: Austria
Member: 2682566 Status: Offline Thanks Meter: 0 | Server problem [Answered] I can't connect to the server. Where is the problem, worked fine yesterday. UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A405FN Software version: 45.14 Checking Login and Password... could not connect to server Checking Login and Password... canceled Done with Samsung Tool PRO v.45.14 [SM-A405FN,Read Codes via Server] |
