Old 08-08-2019, 18:03   #1 (permalink)
hafiz4saqib's Avatar
Member: 2289628
Thanks Meter: 220
SM-A105F Please get the approval to use factory binary (Pit) [Answered]
I get error "Please get the approval to use factory binary (Pit)"
When I want to write combination on SM-A105F but failed with PIT error.
I read PIT in download mode and even also extracted from combination but both PIT are not working.
  FLASH INSTRUCTIONS:
  1. Choose correct flash file(s).
  2. If you have PIT file chosen, then you must check 'Repartition' option.
  3. Check flashing options if needed (Repartition, EFS clear, Boot update).
  4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
  5. Connect the phone to PC with USB cable, install drivers if needed.
  6. Press 'Flash' button.
Operation: Flash
Selected model: SM-A105F
Software version: 37.0
File analysis... OK
Total file size: 0x02400000 (36 Mb)
Searching USB Flash interface... COM5 detected
Setup connection... OK
Set PIT file... Error
Done with Samsung Tool PRO v.37.0
Even Odin3 failed to write combination.
Mobile and combination files are same firmware A105FDDU2ASF2
How to resolve this issue ?
Old 08-08-2019, 19:33   #2 (permalink)
Member: 2613252
Thanks Meter: 1,834
  FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
Hello, samsung with the new firmware with the binary 2 and the new security patches of June July for the new 2019 models, has closed the possibility of writing the combination file on the phone for this gives you this error while flashing the combination:
At the moment there is no way to write the combination file then reset the frp via adb, if you need to reset the fp you need to use the free sim pin method or the smart switch method free
Sim pin method, in the link of the video I posted you will find instructions on how to proceed
https://www.youtube.com/watch?v=mQQtXYkLtPo
Or the smart switch method in the video link that I posted to you will find instructions on how to proceed
https://www.youtube.com/watch?v=_J7To_t3yMk
Unfortunately at the moment if you read on the forum there are many posts like yours where many users are unable to write the combination file because of the new, safety features, at the moment there are no solutions other than those I wrote above
The Following User Says Thank You to amleto90 For This Useful Post:
Old 08-14-2019, 15:11   #3 (permalink)
Member: 311979
Sonork: 1602711
Thanks Meter: 18
samsug A10 SM-105F same problem?
Old 08-24-2019, 10:54   #4 (permalink)
Member: 2289628
Thanks Meter: 220
Yes!
If it has update security after June or July 2019 then combination can`t write.
The Following User Says Thank You to hafiz4saqib For This Useful Post:
Old 09-19-2019, 06:46   #5 (permalink)
Member: 2885667
Thanks Meter: 37
did some one flash combination file. i want to flash combination file not want to remove frp please help me.
Old 09-19-2019, 07:40   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 184,687
all phones has new security.
wait for update.
The Following 7 Users Say Thank You to blang For This Useful Post:
Old 09-23-2019, 12:34   #7 (permalink)
Member: 2796172
Thanks Meter: 42
Do we have any update already?
Old 09-23-2019, 16:34   #8 (permalink)
Member: 2786058
Thanks Meter: 4
wait for update.
Can you tell us when a new update is coming ?!
This Week ?
This Month ?!
The Following User Says Thank You to Android IR For This Useful Post:
Old 11-24-2019, 03:10   #9 (permalink)
Member: 976188
Thanks Meter: 6
Hi, I same the problem, any solution for this SM-A105M?
The solution the sim free, not is the solution. Help me please!!
Old 12-04-2019, 06:24   #10 (permalink)
Member: 1578597
Thanks Meter: 35
Old 12-04-2019, 10:39   #11 (permalink)
Member: 1356561
Thanks Meter: 431
  FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
Hello.
RMM:
RMM stands for Remote Monitoring and Management. It doesn't let the users to get root access to their device. This way it prevents the users to flash custom ROMs. RMM State lock is enabled when you format or reboot your device. ... Let's say wants to switch from One custom ROM to other.
KG State:
Back in December 2017, Samsung pushed a new security feature to its device’s bootloaders to fight against theft protection. This new security feature appears as ‘RMM State’ or “KG State” when your Samsung Galaxy device is booted into Download Mode.
In a nutshell, the problem arises when the KG/RMM State is set to ‘Prenormal’. In that case, it will prevent you from flashing custom binaries like TWRP or carrying out any other sort of modifications to the phone’s software.
Old 12-04-2019, 10:42   #12 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,616
unlock bootloader first then flash official firmware.
Old 01-23-2020, 15:43   #13 (permalink)
Member: 1028644
hi how are u? did u find any solution?
Old 01-23-2020, 16:31   #14 (permalink)
Member: 444048
Thanks Meter: 50
pit file
  FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
you should "check" the repartition box option then flash
read instruction when you have pit file must repartition
Old 01-23-2020, 20:39   #15 (permalink)
Member: 444048
Thanks Meter: 50
get pit
do not work no good.... anyone with good solution thanks ALL
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.21804 seconds with 7 queries
