01-28-2020, 20:53 | #20 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hello, try using this method if it works. FRP BYPASS SAMSUNG 2019 (ANDROID 9.0 PIE) All DEVICE : A10,A20,A30,A40,A50,A60,A70,A90 U2 U3 U4 2020 https://www.youtube.com/watch?v=vDcQ0cNCl24 In case it doesn't work, if you can downgrade the binary 3 a205u firmware to the older security patch of the binary 3 a205u firmware that you have installed on the phone, based on the carrier of the firmware you have installed on the phone and then repeat the method in the video to reset frp if even this method in the video does not work, unfortunately there is no solution at the moment Last edited by amleto90; 01-28-2020 at 21:01. |
01-28-2020, 21:04 | #21 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: usa
Member: 444048 Status: Offline Thanks Meter: 52 | get pit approval Quote:
thanks anyway | |
03-25-2020, 08:00 | #23 (permalink) |
Banned Join Date: Dec 2018 Location: India
Member: 2885667 Status: Offline Thanks Meter: 39 | We need a verified pit file to flash combination file. use z3x box to read pit file. pit file must be same version which you are going to flash. i have read the solution from flash combination with pit but this solution is incomplete. Last edited by how2solutions; 03-25-2020 at 08:02. Reason: improve |
11-20-2020, 00:08 | #24 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | did you succed? I tried with pit file and got same error. Am trying to write same Bit Combination, what I did was Extract PIT file from combination, tried to flash, didnt work. I Read pit file from phone , tried to flash combination with the read pit file, and it didnt work either. At this point, I need more information about this method, as far as I know there is no way to get a pit file for the exact Combination version. any other Tip ? Quote:
11-23-2020, 14:35 | #25 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: ARG - AZUL
Member: 226845 Status: Offline Thanks Meter: 78 | This is told many times yet. New security, need eToken key for flashing combination, in this case. Regards. Quote:
