02-05-2020, 16:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | SM-A105G flashing Problem !! [Answered] I try to flash 3 latest firmware, with odin, Z3X but problem is same FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A105G Software version: 39.1 File analysis... OK Total file size: 0x10714F991 (4209 Mb) Searching USB Flash interface... COM3 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending cm.bin.lz4... OK Sending vbmeta.img.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending dt.img.lz4... OK Sending dtbo.img.lz4... OK Sending system.img.lz4... OK Sending vendor.img.lz4... OK Sending userdata.img.lz4... error Done with Samsung Tool PRO v.39.1 |
02-05-2020, 21:12 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hello, what binary firmware for a105g did you flash the firmware? How did you flash the firmware using the 4 files ap, bl.cp, csc or ap, bl, cp, home_csc, or did you use the single firmware file did you encounter the same error userdata img error? Have you tried with z3x by loading the 4 firmware files, selecting the ap item from z3x by deselecting the single userdata img file and then you have tried to flash the firmware? | |
02-06-2020, 04:24 | #3 (permalink) |
Member: 1369772 Status: Offline Thanks Meter: 297 | Thanks for replay, i already try all the way. if i skip user data, flashing success., But problem is same, phone hang on logo. Can you post single file firmware link ??? |
02-06-2020, 07:52 | #4 (permalink) | |
https://updato.com/firmware-archive-...t=1&q=SM-A105G When you tried to flash the firmware with odin did you use version 3.14.1 giving the same error userdata img error? | |
02-06-2020, 12:34 | #6 (permalink) | |
Have you tried to flash the firmware 4 file with z3x by unchecking the userdata and metadata fota entries from ap to see if it still gives an error? | |
