04-13-2023, 00:09 | #1 (permalink) |
Registered User Join Date: Aug 2005 Location: Sri lanka Age: 43
Member: 171336 Status: Offline Thanks Meter: 61 | s10+ g975u network unlock fail Selected model: SM-G975U Software version: 45.9 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... OK Reading IMEI... OK Model: SM-G975U Android version: 12 PDA version: G975USQU8IWB5 CSC version: G975UOYN8IWB5 Phone version: G975USQU8IWB5 Product code: SM-G975UZKASPR CSC country code: USA CSC sales code: SPR Carrier ID: SPR Phone SN: R58M22*** IMEI: 352695100**** HW version: REV1.0 RF cal date: 2019.02.19 Chip name: SM8150 Modem board: SM8150 Security patch: 2023-02-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Waiting for device to become ready... OK Reading IMEI... OK Initialization zTool... OK Running zTool, please wait... OK Initialization... error (0.6) Done with Samsung Tool PRO v.45.9 [SM-G975U,Unlock] how to unlock please help team |
04-14-2023, 13:52 | #3 (permalink) |
Member: 171336 Status: Offline Thanks Meter: 61 | down grade firmware done but still cannout unlock UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To unlock using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G975U Software version: 45.9 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... OK Reading IMEI... error(0) Model: SM-G975U Android version: 12 PDA version: G975USQS8IVL1 CSC version: G975UOYN8IVL1 Phone version: G975USQS8IVL1 Product code: SM-G975UZKASPR CSC country code: USA CSC sales code: SPR Carrier ID: SPR Phone SN: R58M22T8GLZ IMEI: HW version: REV1.0 RF cal date: 2019.02.19 Chip name: SM8150 Modem board: SM8150 Security patch: 2022-12-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Waiting for device to become ready... OK Reading IMEI... error(0) Please check Samsung USB drivers. Disable screenlock(PIN, password, fingerprint and etc...) Done with Samsung Tool PRO v.45.9 [SM-G975U,Unlock] |
