SM-A700FD Unlock OK by ZX : First in the World :D http://i1293.photobucket.com/albums/...psnujkmjfu.png Quote:
Sir does it need to ROOT this phone to be unlocked? TIA.. :D |
can you shared the complete procedure sir on how to unlocked that kind of unit? thanks |
how to root need root file........... |
SM-A700FD Unlock OK by ZX : First in the World :D |
A700FD unlocked UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-A700FD Selected port: COM34 RIM Virtual Serial Port v2, Software version: 21.3 Waiting ADB device... OK Reading phone info... Model: SM-A700FD Android version: 4.4.4 Product code: SM-A700FZWDXME Phone version: A700FDDDU1AOB1 PDA version: A700FDXXU1AOAA CSC version: A700FDODD1AOA4 CSC country code: India CSC sales code: INU HW version: MP 0.700 Phone S/N: RF8G30LDYEY Modem board: MSM8939 RF cal date: 2015.03.08 IMEI: 358637062335028 Checking Super user right... true Initialization RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.21.3 |
Operation: Unlock Selected model: SM-A700FD Selected port: COM155 SAMSUNG Mobile USB Serial Port Software version: 23.9 Reading phone info... Reading IMEI... OK IMEI: 358637067867264 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.9 |
any one got certificate file for this? |
Welcome to Octoplus/Octopus Box Samsung software version 2.1.6 ----------------------------------------------------------------------------------- To connect SM-Z130H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Enter "*#0808#" number. 3. Select "USB Configuration". 4. Select "USB-Phone(Modem) Chip". 5. Press Home button. 6. Enter "*#0808#" number. 7. Select "Qualcomm USB Configuration". 8. Select "USB-MTP-SDB". 9. Press Home button. ----------------------------------------------------------------------------------- To connect GT-I8262 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Firmware compiled date: Thu Nov 5 20:43:16 KST 2015 PDA version: J700FXXU1AOK2 CSC version: J700FOJV1AOK2 SW version: J700FXXU1AOK2 Phone IMEI: Unknown Phone SN: R28GC1BZMZX Android version: 5.1.1 (LMY48B) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J700F Detected phone model: SM-J700F Firmware compiled date: Thu Nov 5 20:43:16 KST 2015 PDA version: J700FXXU1AOK2 CSC version: J700FOJV1AOK2 SW version: J700FXXU1AOK2 Phone SN: R28GC1BZMZX Android version: 5.1.1 (LMY48B) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J700F-Unknown04-01-2016_16-14-57-.asec file Unlocking phone. This can take some time. Please wait... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J700F Software version: 23.9 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J700F Android version: 5.1.1 Product code: SM-J700FZDDKSA Phone version: J700FXXU1AOK2 PDA version: J700FXXU1AOK2 CSC version: J700FOJV1AOK2 CSC country code: KSA CSC sales code: KSA HW version: MP 0.701 Phone S/N: R28GC1BZMZX Modem board: SHANNON310 RF cal date: 20151209 IMEI: Checking Super user right... true Reading nv data... OK OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.9 |
