08-28-2015, 06:50 | #2 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1773961 Status: Offline Thanks Meter: 0 | Z3X box never achieved sucess in unlocking us cellular variants. Try sending SPC and 16 digit password from any cdma tool like DFS / CDMA workshop and after that try unlocking from Z3x. Post results here. |
09-20-2015, 08:35 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | Quote: select samsung usb port set SPC to 000000 and press run ( play button ) you will see device is unlocked in log set pwd to 2013051320130909 and press run ( play button ) you will see device is unlocked in log then run z3x and unlock | |
12-22-2015, 09:29 | #8 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Flash Selected model: SM-G900R4 Software version: 23.8 File analysis... OK Total file size: 0x97B305B8 (2427 Mb) Searching USB Flash Interface... detected COM22 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Flashing done (time - 00:04:07) Done with Samsung Tool PRO v.23.8 unable to unlock and activate diag port please help mr. blang |
12-22-2015, 09:30 | #9 (permalink) |
Member: 1849215 Status: Offline Thanks Meter: 136 | Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G900R4 Android version: 5.0 Product code: Not Active Phone version: G900R4VXU2BOG2 PDA version: G900R4VXU2BOG2 CSC version: G900R4USC2BOG2 CSC country code: USA CSC sales code: USC HW version: G900R4.02 Phone S/N: 00000000000 Modem board: MSM8974PRO RF cal date: 2014.10.06 IMEI: Activating diag... OK Activation diag done Done with Samsung Tool PRO v.23.8 |
06-14-2016, 14:49 | #10 (permalink) |
Junior Member Join Date: Oct 2015 Location: amman.jordan
Member: 2470859 Status: Offline Sonork: zakaria Thanks Meter: 1 | Operation: Unlock Selected model: SM-G900R4 Selected port: COM129 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: 990004468734243 Reading security... new type Bypassing... error Done with Samsung Tool v.20.5 |
06-15-2016, 07:08 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,587 | Quote:
02-07-2019, 13:53 | #12 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | This phone still not supported yet ? UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900R4 Selected port: COM107 SAMSUNG Mobile USB Serial Port Software version: 34.8 Reading phone info... Reading IMEI... OK IMEI: 990005840923313 Unlocking... error (02) Done with Samsung Tool PRO v.34.8 |
