12-23-2016, 10:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | SM-A710S need reset strange lock !!!! need your help!! The phone lock is search owner phone. Please need solution !!!! Code: UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Pattern lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset Pattern Lock Selected model: SM-A710S Software version: 27.5 Checking local file... not found Searching server... Ok Downloading file... Ok Checking local file... Ok Searching USB Flash interface... COM49 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 5.1.1 Boot version: A710SKSU1BPI4 Platform: exynos7580 Boot serial: 3300eda6c776a255 Product board: a7xelte Erasing locks... Ok Rebooting phone... Ok Reset locks done But nothing change lock is still Done with Samsung Tool PRO v.27.5 |
12-23-2016, 10:22 | #2 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | http://forum.gsmhosting.com/vbb/f684...016-a-2170007/ Please look pictures phone status now. |
