1000000% worked thank you I was at this for hours!! and this worked. I had already flashed the Aofa firmware and tried to use various model phones. this model was the only one that worked!! Thanks a million man!! Quote:
Using G361H worked on Z3X. Thanks Originally Posted by medo_mshakel View Post |
Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 30.1 Searching Samsung USB Flash interface... COM14 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.30.1 thanks bro. it worked by selecting g361h/ds only |
Thanks bro its work for me |
thx for sharing with us |
I am having the problem. Below is the log. I flashed "G360T1UVU1AOFA_TMB1AOFA" and tried to do the FRP reset and got the below error. Any help please! Operation: Reset FRP/React/EE Selected model: SM-G360T1 Software version: 30.7 Searching Samsung USB Flash interface... COM24 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.30.7 |
Plz flash combination file then do FRP reset Sent from my iPhone using Tapatalk |
Since I have the TMobile phone so I download just the TMobile file from below link. Am I right? Finally for Tmo, flash only the boot.img from this package: https://www.androidfilehost.com/?fid=457095661767155675 |
Actually I followed tabbudzaid's method. I selected "SM--G361H/DS" instead of "SM-G360T1" and did the FRP and it worked. No need to flash the boot file. It worked for me. Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 30.7 Searching Samsung USB Flash interface... COM24 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.30.7 |
thanks for this solutions it works for me thanks a lot |
1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 33.4 Searching Samsung USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.33.4 |
SM-G360T1 FRP unlock error G360T1UVU2AQD1, not rooted Operation: Reset FRP/React/EE Selected model: SM-G360T1 Software version: 33.5 Searching Samsung USB Flash interface... COM6 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... error Done with Samsung Tool PRO v.33.5 I tried to select G360T - same error |
This http://forum.gsmhosting.com/vbb/f453.../#post12545557 worked like charm thanks! How do I SIM unlock Metro version? If I do unlock from the program it asks me for some server login - not worth paying for this tiny cheap phone... |
no need to download whole package just use below files and select g361f for frp reset download mode https://doc-0s-2k-docs.googleusercon...Pe7?e=download |
