SM-G531F imei repair problem Hi. Im using latest SamsungTool Pro (v.25.3) and i can not install TWRP on G531FXXU1APC2 so i used preRooted firmware G531FXXU1AOF7 and G531FXXU1AOH1 but on both is same issue. Can not use any code, even imei check does not work (*#06#), so i can not type *#0808# any suggestion? on G531FXXU1APC2 it works (*#0808#) but i can not root, even if i will instal TWRP and SuperSU via TWRP, is still after adding google account i can not go to TWRP (custom binary bloacked by FRP Lock). Quote:
*flash your phone with stock rom *go recovery and do factory reset *boot phone normally, and go setting enable oem unlock and usb debugging *reflash with pre-rooted firmware *now you have rooted phone |
great, but then does not work *#0808# and i can not do imei repair. |
do not use *#0808# you do not need it after you have root just connect to z3x (usb debugging is on) and box will see adb ( hit allow in phone screen) |
but i do not have imei repair option, only mac, serial number, but no imei... |
ok, but how can i edit imei in cert? |
u cant unfortunately so if u dont have have backup of yr phone, then u cant repair imei by writing cert form another phone,other imei will be written in your phone |
Done with Samsung Tool PRO v.29.2 plz help what i do |
