SM-G531F Reset FRP/React/EE Erasing EE lock... error >>Help Me Hello Everyone I Have Samsung SM-G531F &This Mobile In FRP Lock I Do This This Mobile Flash With 2 different Firmware But Not Removing FRP Lock. some users Was Doing fixing this by flashing Please Give Me Tested Firmware. Log Bellow UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 25.1 Searching Samsung USB Flash Interface... detected COM24 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.1 I Was Try Z3X Many Software Like AS: 1.SamsungToolPRO_25.1 2.SamsungToolPRO_25.0 3.SamsungToolPRO_24.9 4.SamsungToolPRO_23.9 But Problem Same kindly Please Help Me Thanks & Regards By : Gopal Parmar |
What FW does G531F have? Br, xerraco |
First= G531FXXU1AOH1_Rooted_Firmware_v5.1.1_New.zip Second=G531FDDU1APB2_ODD1APC1.zip Both Via Flash Success But Problem Not Solve |
Please Anyone Tell Me Solution Please |
http://forum.gsmhosting.com/vbb/f777...azone-1990399/ try this sulation...... or try miracle box.... |
Thanks Sir Your Solution Working Well In SM-G531F Thanks Again !!!!!!!!!!!!!!!!! |
please help me how to remove frp on this device thanks |
Bro, try this way out. Hope ur problem solves. I know it is for J700F, but it may also work for All latest phones. http://forum.gsmhosting.com/vbb/11786625-post1.html 2nd method http://forum.gsmhosting.com/vbb/11788409-post15.html |
if otg not work flash with g531f root file after otg work good |
http://forum.gsmhosting.com/vbb/f453...count-2092541/ |
flash this file in BL then reset with box Dev-Host - FRP_G531F_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service only thanks button T |
Any other solution? |
Flash with this firmware and than do reset G531HXXU0AOH8 |
its g531f not g531h !! do the steps 100% correct and it will be 100% bypassed (easy steps). |
