Old 03-20-2019, 18:01   #1 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
h345 unlock done but only Serching no netwok
3/17/2019 8:47:29 PM: Mode: Normal
3/17/2019 8:47:29 PM: Model:
3/17/2019 8:47:29 PM: Build version: xð~
3/17/2019 8:47:29 PM: SW Version:
3/17/2019 8:47:29 PM: IMEI: BAD IMEI
3/17/2019 8:47:29 PM: BlueTooth Address: 00:00:00:7E:BB:01
3/17/2019 8:47:29 PM: Phone Code:
3/17/2019 8:47:29 PM: Elapsed: 0 secs. --> (v9.60)
3/17/2019 8:47:29 PM: Checking Login and Password...
3/17/2019 8:47:31 PM: OK
3/17/2019 8:47:31 PM: Ballance:
3/17/2019 8:47:31 PM: 26 crd.
3/17/2019 8:47:32 PM: You have 26 credit(s) left. This operation takes 10 credits.Continue?
3/17/2019 8:47:32 PM: Yes
3/17/2019 8:47:33 PM: Searching modem interface...
3/17/2019 8:47:33 PM: found COM197
3/17/2019 8:47:33 PM: Reading data from phone...
3/17/2019 8:47:33 PM: OK
3/17/2019 8:47:33 PM: IMEI: BAD
3/17/2019 8:47:34 PM: Checking root rights...
3/17/2019 8:47:34 PM: OK
3/17/2019 8:47:35 PM: Writing zTool...
3/17/2019 8:47:36 PM: OK
3/17/2019 8:47:36 PM: SW Version: H34510e
3/17/2019 8:47:36 PM: Initialization zTool...
3/17/2019 8:49:06 PM: OK
3/17/2019 8:49:06 PM: Reading data from phone...
3/17/2019 8:49:33 PM: OK
3/17/2019 8:49:33 PM: Calculating...
3/17/2019 8:49:34 PM: OK
3/17/2019 8:49:34 PM: Searching server...
3/17/2019 8:50:00 PM: OK
3/17/2019 8:50:00 PM: Waiting for server answer...
3/17/2019 8:50:13 PM: OK
3/17/2019 8:50:13 PM: Initialization zTool...
3/17/2019 8:50:14 PM: OK
3/17/2019 8:50:14 PM: Reading data from phone...
3/17/2019 8:50:16 PM: OK
3/17/2019 8:50:16 PM: Unlocking done
3/17/2019 8:50:16 PM: Elapsed: 164 secs. --> (v9.60)
3/17/2019 9:04:45 PM: Port already opened!
3/17/2019 9:04:45 PM: Elapsed: 0 secs. --> (v9.60)
i tried to write qcn from support but still the same
Mode: Normal
Model: EAAAANVZ
Build version: Jun 16 201517:42:27May 11 201500:00:00EAAAANVZ
SW Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1.19638.1.19833.1
IMEI: 35956206955575-9
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
Elapsed: 1 secs. --> (v9.60)
Reading QCN file... OK
Checking phone at COM196
Detected ID: 00000FFE (MSM8916)
Read SPC...
SPC: 000000
Unlock SPC... OK
Checking paths... OK
Restoring EFS Backup... OK
Restoring NV Items... OK
Restoring NV Item SIM1... OK
Restoring NV Item SIM2... OK
Restoring Provisioning Item Files... OK
Elapsed: 19 secs. --> (v9.60)
so whats the problem ??
Old 03-20-2019, 18:02   #2 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
i tried also to reset sec zone but its return locked again so if i reset sec zonr and do unlock again it will consume credit again ?
Old 03-20-2019, 19:16   #3 (permalink)
Member: 2085676
Thanks Meter: 299
Pease try to repeat the "Unlock" operation again and then after unlocking reboot the phone manually. Write here the result.
Old 03-20-2019, 19:17   #4 (permalink)
Member: 2085676
Thanks Meter: 299
or try new firmware version and rooted
Old 03-20-2019, 22:09   #5 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
if i do unlock again it will take credit one more time ?
Old 03-22-2019, 14:14   #6 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hello,
Server charge only once if phone + dongle is same.
Old 03-24-2019, 15:04   #7 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
could u tell me the steps to repair network i tried to reset sec zone but after that imei changed to 0 so restored the old sec zone but still serching
Old 03-24-2019, 17:07   #8 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Better way is:
make sec reset
write QCN from good phone
repair IMEI
Make Unlock again - server can't charge credits again.
Old 03-24-2019, 20:14   #9 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
after this steps got this error when unlock
Mode: Normal
Model: EAAAANVZ
Build version: May 21 201517:05:03Apr 22 201505:00:00EAAAANVZ
Phone Code: default
Checking Login and Password... OK
Ballance: 31 crd.
You have 31 credit(s) left. This operation takes 10 credits.Continue? Yes
Searching modem interface... found COM197
Reading data from phone... OK
IMEI: 359562069555759
Checking root rights... OK
Writing zTool... OK
SW Version: H34510d
Initialization zTool... OK
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Reading data from phone... error(10 7.10300)
Elapsed: 142 secs. --> (v9.60)
Old 03-24-2019, 20:22   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Try now. We fixed this problem.
Old 03-24-2019, 22:18   #11 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
unlocked but still same problem searching. and it took 10 credit i think u already ad them !
when i go to settings and search for network it fount but cant register on network
Old 03-24-2019, 22:19   #12 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
We refund this phone. This phone after wipe and no way for unlock.
Page generated in 0.17164 seconds with 8 queries
