11-03-2017, 17:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Poland
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | SM-G920F Reactivation lock remove [Done] 2. write combination file with odin, when phone boot up, turn off. 3. install z3x version 25.5 4. phone turn on download mode (vol-, home and power) 5. on z3x on tab 920f tab unlock and click reset FRP/React/EE 6. check in download mode reactivation lock is OFF 7. flash any stock firmware with B:5 sw revision (Binary 5) (latest DATE version of firmware, 6.0 or 7.0) 6.0 UK firmware clear latest date firmware link download Done |
The Following 13 Users Say Thank You to rudy178 For This Useful Post: |
05-28-2018, 11:18 | #5 (permalink) | |
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | Quote:
After unlock, write LATEST firmware 7.0 | |
The Following 3 Users Say Thank You to rudy178 For This Useful Post: |
06-04-2018, 11:50 | #8 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | [QUOTE=Stevette;13164339]not working with B6. Any solution to get it done? Thanks a lot for hi, use the ufs memory method with uart cable with z3x to bypass Google's frp block, here you can find the video of how to do and instructions * https://m.youtube.com/watch?v=VfygzlDlg6E |
06-05-2018, 09:09 | #9 (permalink) | |
Junior Member Join Date: May 2018
Member: 2839516 Status: Offline Thanks Meter: 2 | [QUOTE=amleto90;13164830] Quote:
Thank you for your help my friend but this only works with "S7" I got a S6-G920F I try that a few times but it's not working with the newest security Update. Maybe there is an other solution? Thanks for your help Best regards | |
06-05-2018, 10:29 | #10 (permalink) |
No Life Poster Join Date: May 2005 Age: 61
Member: 147694 Status: Offline Thanks Meter: 69 | [QUOTE=Stevette;13166007]It work even with B6 The trick is. Write COMBINATION file. Then select g531f (not g920f or g925F) pres Reset FRP/React/EE. than put again in download mode and you'll see Reactivation Lock has gon. Now you can flash with latest firmware |
The Following 22 Users Say Thank You to arimob For This Useful Post: |
06-05-2018, 13:04 | #11 (permalink) | |
Member: 2839516 Status: Offline Thanks Meter: 2 | [QUOTE=arimob;13166133] Quote:
Is there maybe also a solution to get it unlocked with the newest security update? I try everything... Combination ... root but nothing works. If there is a solution to solve my problem that would be great. Best Regards | |
The Following User Says Thank You to Stevette For This Useful Post: |
07-09-2018, 23:58 | #12 (permalink) | |
Junior Member Join Date: Jun 2018 Location: United States of America
Member: 2843359 Status: Offline Thanks Meter: 0 | [QUOTE=arimob;13166133] Quote:
WORKING! THANKS! | |
11-05-2018, 14:18 | #15 (permalink) | |
Insane Poster Join Date: Aug 2011 Location: United States
Member: 1629444 Status: Offline Thanks Meter: 47 | [QUOTE=arimob;13166133] Quote:
thanks | |
The Following 2 Users Say Thank You to BBoyGSM For This Useful Post: |
