03-02-2016, 17:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: libya Age: 44
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | sm-g925f android version 6.0.1 imei problem running z tool , please wait .... errorr 7.7.8 any one have idea or advice best regards |
03-02-2016, 18:43 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | They didnt upgrade the rollback protection bit it is still a 3. Just downgrade the modem to OJ1 and use z3x 23.9 CLICK HERE TO DOWNLOAD G925F OJ1 MODEM CLICK HERE TO DOWNLOAD Z3X 23.9 |
The Following User Says Thank You to markhaines1985 For This Useful Post: |
03-03-2016, 11:44 | #5 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | @ markhaines1985 are you tested this solution ? when flash with different modem phone gone unknown modem and imei null whats full firmware android 6.01 work with modem G925f Oj1 without imei null |
03-05-2016, 14:56 | #6 (permalink) |
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Look at the 3 firmwares below. The middle digit in all of them that I have underlined is what is called the rollback protection bit (RP). As long as that bit is the same or higher than the one of the current firmware on phone you can flash that rom. PBF has same RP as OJ1 that means you can flash OJ1 on a phone with PBF without any issues. That means you can downgrade just the modem without causing an unknown baseband. However, if your phone is on PBF and you flash the OFN rom to it it will cause the baseband to be unknown since the RP is 2 which is lower than the RP of 3 on PBF. G925FXXU3DPBF 6.0.1 G925FXXU3COJ1 5.1.1 G925FXXU2BOFN 5.1.1 |
The Following 8 Users Say Thank You to markhaines1985 For This Useful Post: |
03-05-2016, 17:10 | #7 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | my phone baseband version is g925FXXU3DPBK U mean if i flash my phone with one file modem G925FXXU3COJ1 by phone will not go imei null |
03-05-2016, 18:36 | #9 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | @ markhaines1985 I am so so so thanks its done with your help but can i ask u ? how can i know correct modem version of my phone imei by sn ? best regards |
03-06-2016, 00:40 | #10 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
03-15-2016, 18:05 | #11 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2546388 Status: Offline Thanks Meter: 2 | Quote:
Luego de la actualizacion a 6.0.1, un cliente me trajo un G925F que decia "solo llamadas de emergencia". Luego de 2 dias tratando de reparar redes, escribir cert, etc logre solucionarlo flasheando el modem que dejaste. Me tiraba error z3x, tanto como octopus antes de flashear tu modem. El procedimiento lo hice con z3x Samsung Tool Pro V24.7 y salio sin problemas: 1 - Flasehar MODEM_G925F_OJ1, con Odin v3.10.6 en la pestaņa PHONE 2 - Rootear con CF-Auto-Root-zerolte-zeroltexx-smg925f 3 - En z3x pestaņa "Repair" dar a Reset EFS (recuerden hacer un backup antes) 4 - Escribir nuevamente el IxxI, dar en "Repair" 5 - Dar en "Patch Certificate" (Luego de esto ya deberia dar seņal, pero si ponen *#06# veran que S/N figura vacio) 6 - Para recuperar el S/N vuelven a escribir la EFS. Pestaņa "Backup" dan en "Write EFS" y buscan el backup que habian hecho anteriormente. Esa fue mi experiencia y todo se realiza con Samsung Tool PRO v24.7. En octopus no alcance a relizar el procedimiento pero calculo que se debe solucionar tambien. Gracias | |
The Following 2 Users Say Thank You to kechup10 For This Useful Post: |
03-28-2016, 23:02 | #14 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: Paraguay
Member: 1110740 Status: Offline Thanks Meter: 383 | Quote:
tengo el mismo problema, mi g925f esta en modo solo llamadas de emergencia, si serias tan amable de pasar el link solo del modem que utilizaste | |
04-16-2016, 07:43 | #15 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: pakistan
Member: 355565 Status: Offline Sonork: 1597522 Thanks Meter: 95 | Quote:
The Following 3 Users Say Thank You to super decent For This Useful Post: |
