Old 02-23-2016, 12:02   #1 (permalink)
Member: 1086393
Thanks Meter: 771
SM-g925i samsung account bypass
Hi
Can't unlocked new 5.1.1 reactiavtion lock on g925i
Operation: Reset FRP/React/EE
Selected model: SM-G925I
Software version: 24.2
Searching Samsung USB Flash Interface... detected COM6
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... error
Done with Samsung Tool PRO v.24.2
Need help.
Old 02-23-2016, 12:54   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Hi bro.. If it's old security try with 24.3 i have same Problem j500H with 24.2 but done via 24.3
Old 02-23-2016, 12:59   #3 (permalink)
Member: 1086393
Thanks Meter: 771
hi,
I have solved the problem.
Thanks anyways.
its been long , nice to meet you again
The Following User Says Thank You to Riteshgpt60 For This Useful Post:
Old 07-23-2016, 04:05   #4 (permalink)
Member: 1886939
Sonork: 100.1650305
Thanks Meter: 78
Originally Posted by Riteshgpt60 View Post
hi,
Thanks anyways.
can you please explain how you solved im facing exact same issue i already tried z3x 23.4 v but still same issue
Sent from my iPhone using Tapatalk
Old 10-31-2016, 17:54   #5 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
g925i samsung account bypass dead
i have a g925i trying to reset frp using z3x, phone dead
any solution to bypass samsung account
thx
Old 11-01-2016, 05:51   #6 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
thx
Yes, many solutions but it depends of SW version you have installed in phone. Comment a bit more about your device and procedure you tried.
Old 11-01-2016, 15:48   #7 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
i try frp reset using z3x software, phone dead
Old 11-01-2016, 21:12   #8 (permalink)
Member: 1326581
Sonork: (((NAEEM)))
Thanks Meter: 52
i can't blve this plz chek batrry and retry downloding mode
Old 11-01-2016, 21:43   #9 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
If you want help please answer this:
- Which software version is installed in phone, and build number?
- I think you used standard method in download mode, but tell me if it is right and if you tried another method.
- Is your phone alive now? what do you mean exactlywith "phone dead"?
- You can put in recovery/download mode?
Also in google and here in forum you will find many methods, some with downgrade, some with sidesync and some with combination firmware. You can search and try some of them, or if you you preffer I can help you but I can't if don't know any info about your handset.
The Following User Says Thank You to joel_3mo For This Useful Post:
Old 11-03-2016, 17:37   #10 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
it's about samsung account lock
i try to use frp in z3x but it was dead
i can't downgrade , because it give error
only version of software accepted is : G925IDVS3EPC1_G925IKSA3EPB4
thx for help
Old 11-03-2016, 19:54   #11 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
thx for help
Ok, now lets see.
First you can try to use sidesync method, search it here in forum and in google, there is a lot of info for this method. First downgrade fimware to an older version, ALL PARTS EXCEPT BOOTLOADER (sboot.bin and cm.bin), then make a factory reset and only then use sidesync method.
Anyway if you can't, I could try to share engineering kernel for easyer way.
Old 11-04-2016, 07:39   #12 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
Ok, now lets see.
Here you have an example. Universal Samsung FRP Bypass | RootJunky.com
Here is file for enable ADB: http://www.4shared.com/file/p0YSqyBr...2_ENG_KER.html
Old 11-04-2016, 16:12   #13 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
Ok, now lets see.
thx for answer but sidesync method don't work for samsung account
Old 11-04-2016, 18:11   #14 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
Universal Samsung FRP Bypass | RootJunky.com work test me
Old 11-04-2016, 18:13   #15 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
It's samsung account security
not google account that's the problem
Page generated in 0.26494 seconds with 10 queries
