02-05-2018, 21:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g925t latest build unlock done ra3 build New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G925T Selected port: COM263 SAMSUNG Mobile USB Serial Port Software version: 30.7 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM2G925TZDATMB Phone version: G925TUVS6FRA3 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58GA1QLKQW Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: 20151019 IMEI: 359715062643812 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: C8 34 AE 6D F4 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.7 |
The Following 3 Users Say Thank You to ghacks For This Useful Post: |
02-08-2018, 16:36 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | thanks. all is ok. post log. Quote:
