Old 12-03-2017, 05:46   #1 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
Thumbs up Samsung A500F cert write problem
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-A500F
Selected port: COM416 SAMSUNG Mobile USB Serial Port
Software version: 30.1
Checking CERT file... OK
KEY ID: 0756
Waiting ADB device... OK
Reading phone info...
Model: SM-A500F
Android version: 5.0.2
Product code: SM-A5000ZWATGY
Phone version: A5000ZHU1BOL3
PDA version: A500FXXU1BOL3
CSC version: A500FOJV1BOL3
CSC country code: Hong Kong
CSC sales code: TGY
HW version: MP1.101
Phone SN: R28H91G766F
Modem board: MSM8926
Security patch: 2015-12-01
RF cal date: 2016.09.14
IMEI: 2515925302514f0
Writing AT RIL... OK
Initialization AT RIL... OK
Bypass MSL... error (2)
First reset MSL
Done with Samsung Tool PRO v.30.1
When try Reset Msl than show
Reading IMEI... OK
IMEI: xxxxxxxxxxxxxx
Reseting MSL security... error (1)
Old 12-03-2017, 13:41   #2 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
Dear team any answer??????????????????????
Old 12-03-2017, 14:04   #3 (permalink)
Member: 2613252
Thanks Meter: 1,837
Hi, try to downgrade the firmware to the Android 5.0.2 version of the older security patch level. Since you have the firmware installed the Android phone 5.0.2 with security patch level of December, try to degrade the patch level you security Making the flash of another firmware with security patches before October 2015 did this, try rewriting the certificate in the phone and see if it writes it correctly
Page generated in 0.12667 seconds with 8 queries
