Old 12-03-2017, 08:11   #1 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
samsung galaxy s7 g930fd hang on logo after reset frp
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't use this function.
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' to deactivate Google account activation lock.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset Pattern Lock
Selected model: SM-G930FD
Software version: 30.0
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM24 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.30.0
now hang on logo
Old 12-03-2017, 08:33   #2 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
Phone not found
now hang on logo
need this firmware to flash this phone G930FXXS1DQHM
Old 12-03-2017, 08:40   #3 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 731
try wipe data reset or wait some phone take 30 min for bootup
Old 12-03-2017, 09:31   #4 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
bro not working give me flash file link
Old 12-03-2017, 09:52   #5 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
You reset pattern not frp read well reset frp by uart cable and then flash custom recovery but first flash stock boot
Phone not found
now hang on logo
IF YOU LIKE WHAT I POST PRESS THANKS BUTTON
The Following User Says Thank You to souma_k For This Useful Post:
Old 12-03-2017, 11:28   #6 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
done by flashing firmware from support site
Page generated in 0.19221 seconds with 8 queries
