Old 12-14-2018, 13:43   #16 (permalink)
Member: 2014880
Sonork: 100.1673441
Thanks Meter: 26
just flas combination file use g935p to do unlock after flash full firmware job done
The Following 3 Users Say Thank You to julius1461 For This Useful Post:
Old 01-19-2019, 13:14   #17 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Question
have you tested on U5 ?
pls share log
thanks
Old 01-19-2019, 14:26   #18 (permalink)
Member: 930738
Sonork: 100.1652204
Thanks Meter: 8
i have seam problem pls help mee any one have sm-g955u u5 7.0 firmware
Old 01-19-2019, 14:42   #19 (permalink)
Member: 930738
Sonork: 100.1652204
Thanks Meter: 8
i need sm-g955u u5 7.0 firmware
Old 01-19-2019, 15:02   #20 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 163
Wink
check on forum, other box can unlock it successfully
tested now on U5 !
Old 01-25-2019, 01:45   #21 (permalink)
Crazy Poster
Member: 2839691
Thanks Meter: 15
Major fail, z3x. You should gave tested before advertising this. Combination modems opens up possibility to unlock and abuse opening, like s9 (newer unlock style), but combination modem only supports older unlock style, not newer rsa unlock style. Dont make excuses, just remove it the feature, and done.
Old 01-25-2019, 15:20   #22 (permalink)
Member: 92260
Thanks Meter: 843
Don't waste your time flashing anything once on U5 firmware. No matter what you flash it with, which model you select the security is too high to unlock it. Every single log showing a successful unlock is on lower than U5.
Then I tried another tool (Octo) and it unlocked it perfectly via a few credits. Hope Z3X will come out with a solution soon for the latest firmwares because it's obviously possible.
Sending device information...OK
Initializing exploit...OK
Checking lock status...Locked
Unlocking phone...OK
Checking lock status...Unlocked
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu.
Old 01-25-2019, 19:29   #23 (permalink)
Crazy Poster
Member: 2839691
Thanks Meter: 15
It unlocked U5 sprint? And full stock? Or required combination modem?
Old 01-28-2019, 14:55   #24 (permalink)
Member: 92260
Thanks Meter: 843
I don't remember exactly, but I think it was full stock (if not flash the modem SQU5CRF1), but the only box I found to work was the Octo. Waiting for Z3X to add support also.
Old 02-12-2019, 01:16   #25 (permalink)
Member: 2061249
Thanks Meter: 18
which option did you use? the device isn't being read properly for some odd reason during factory unlock services option but it asks for credits on tmb unlock option from the OCTOPLUS SUITE... however it's a sprint device..... so i don't think that's right.
Old 02-13-2019, 02:09   #26 (permalink)
Member: 2061249
Thanks Meter: 18
can anyone refer me to which files i need to flash. i'm on bit 5 RF1 and octoplus fails.
Old 02-13-2019, 04:44   #27 (permalink)
Member: 2569104
Thanks Meter: 42
Hi, already know you guys are talking about the "boxes" but s.a.mkey can do it perfectly since the begining of the solution(1 week later after chimera post their sol), flashing eng modem, but yersterday the come out with an update, unlocking all new security without combo or eng modem.
So like @BillA said before, waiting for the mighty z3x comes with a solution, cause obviously it can be done perfectly
Old 02-18-2019, 20:39   #28 (permalink)
Member: 1278018
Sonork: 100.1683773
Thanks Meter: 13
I FLASH COMBINATION FILE ON G955U BIT5 THEN PHONE WENT DEAD ONLY QUALCOM USB 9008 IS AVAILABLE ON DEVICE MANAGER.
Please customer is on my neck who can help me pleassssssssse
Old 02-20-2019, 20:47   #29 (permalink)
Member: 1066792
Sonork: Pyzia
Thanks Meter: 7
this solution work g955u fw U5
Old 03-14-2019, 17:02   #30 (permalink)
Member: 258227
Thanks Meter: 13
Originally Posted by robertyanta83 View Post
here you go
1) flash this eng modem bit 5 with this patched odin
2) direct unlock with z3x
3) restore stock modem or full flash
i cantg unlock put error 3.0.0.5 probably your phone has old securityand can not unlock by this method
Page generated in 0.22764 seconds with 8 queries
