Old 02-18-2016, 21:49   #1 (permalink)
Member: 399404
Thanks Meter: 70
Can't write Cert- N910T
So when I try to write the cert file I get ( Bypass MSL ) error even after resetting MSL..
Old 02-18-2016, 22:40   #2 (permalink)
Member: 2298894
Try version 19.1. I had a similar problem with 747.
Old 02-18-2016, 23:26   #3 (permalink)
Member: 399404
Thanks Meter: 70
ok so I have try that - with 19.1 and everything goes smooth
but when finishing wiping and phone reboots IMEI remains there.. no changes
Old 02-19-2016, 14:46   #4 (permalink)
Member: 2298894
Try again. Sometimes it will do it during the second attempt.
Old 02-20-2016, 19:51   #5 (permalink)
Member: 399404
Thanks Meter: 70
keep getting the same error ..
I was 5.0.1 same thing, updated to 5.1.1 rooted same thing
tried it with 19.1 more than 3 times and same ..
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-N910T
Selected port: COM27 SAMSUNG Mobile USB Serial Port
Software version: 24.3
Checking certificate file... OK
KEY ID: 0772
Waiting ADB device... OK
Reading phone info...
Model: SM-N910T
Android version: 5.1.1
Product code: SM-N910TXXXTMB
Phone version: N910TUVU2DOK2
PDA version: N910TUVU2DOK2
CSC version: N910TTMB2DOK2
CSC country code: USA
CSC sales code: TMB
HW version: REV1.1
Phone S/N:
Modem board: MDM9225M
RF cal date: 2014.10.16
IMEI:
Initialization AT RIL... OK
Bypass MSL... error (2)
First reset MSL
Done with Samsung Tool Pro
Old 02-20-2016, 23:55   #6 (permalink)
Member: 1288575
Thanks Meter: 36
KEY ID: 0772
Model: SM-N910T
CSC sales code: TMB
HW version: REV1.1
Phone S/N:
IMEI:
First reset MSL
downgrade modem NK4/ reset msl/ Restore modem OK2/ write cert/ profit
The Following User Says Thank You to clippy165 For This Useful Post:
Old 02-25-2016, 18:01   #7 (permalink)
Member: 399404
Thanks Meter: 70
after few tries it did worked ..
Thanks a lot.
Old 02-27-2016, 08:48   #8 (permalink)
Member: 1531854
Thanks a lot.
with z3x 19.1?
regards!!
Old 02-28-2016, 01:02   #9 (permalink)
Member: 399404
Thanks Meter: 70
with 24.4
but downgraded modem to NK4/ reset msl/ Restore modem OK2
The Following User Says Thank You to qtouch For This Useful Post:
Old 02-29-2016, 08:06   #10 (permalink)
Member: 1531854
It works thanks for share this solution
Sent from my SM-G920I using Tapatalk
Page generated in 0.15456 seconds with 8 queries
