02-01-2018, 07:01 | #1 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2429352 Status: Offline Thanks Meter: 72 | Error unlock a320fl readcode Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Read Codes via Server Selected model: SM-A320FL Software version: 30.5 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM37 Reading phone info... OK Model: SM-A320FL AP version: A320FLXXS2BRA9 CSC version: A320FLXEF1BQH5 CP version: A320FLXXS2BRA1 Product code: XEF Phone SN: RF8J92V5QEX Unique number: C0000ECE5B56914 Searching Samsung diag port... detected COM33 Reading phone info... OK CP version: A320FLXXS2BRA1 CP build: Jan 8 2018 15:35:57 Reading data from phone... error (1) Done with Samsung Tool PRO v.30.5 |
02-01-2018, 13:42 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
