10-19-2018, 01:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | SM-J250G U3 still can't unlock via server [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J250G Software version: 34.0 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXS3ARG1 CSC version: J250GOLC3ARG1 Phone version: J250GDXS3ARG3 Product code: SM-J250GZKAXTC CSC country code: PHILIPPINES CSC sales code: XTC Phone SN: R28K51PNQ4Z IMEI: 355738090435XXX HW version: MP0.900 RF cal date: 2018.05.18 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-07-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM33 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (0) please update phone firmware Done with Samsung Tool PRO v.34.0 |
12-07-2018, 23:49 | #2 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
i m having same error Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J250G Software version: 34.3 Checking Login and Password... OK Ballance: 23 crd. You have 23 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU2ARF2 CSC version: J250GVAP2ARG1 Phone version: J250GDXU2ARF2 Product code: SM-J250GZKAVAP CSC country code: Australia CSC sales code: VAP Phone SN: R28K21PCQ3E IMEI: 354062090238371 HW version: MP0.800 RF cal date: 2018.02.13 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM87 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.34.3 | |
12-08-2018, 03:49 | #3 (permalink) |
Crazy Poster Join Date: Jun 2011
Member: 1603632 Status: Offline Thanks Meter: 12 | 1.turn OEM and debugging 2.flash combi same your original version. download combi from z3x support 3.then flash downgrade by full rom version u1 only. just flash only AP and CSC. download full rom from samfirm.exe 4.and then try to unlock again 5.if unlock success then flash lastest full rom. end sory for my bad english. i just want to help my all friend. regard |
12-10-2018, 23:43 | #4 (permalink) | |
Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J250G Selected port: COM3 USB Serial Port Software version: 34.5 Checking Login and Password... OK Ballance: 23 crd. You have 23 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU1ARA1 CSC version: J250GVNZ1ARA2 Phone version: J250GDXU2ARD1 Product code: SM-J250GZKAVNZ CSC country code: New Zealand CSC sales code: VNZ Phone SN: R28K21PCQ3E IMEI: 354062090238371 HW version: MP0.800 RF cal date: 2018.02.13 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2017-11-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM4 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.34.5 Last edited by salim5566; 12-10-2018 at 23:50. | |
12-11-2018, 05:16 | #5 (permalink) | |
12-15-2018, 00:46 | #7 (permalink) | |
here is the log Code: UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J250G Selected port: COM3 USB Serial Port Software version: 34.6 Checking Login and Password... OK Ballance: 8 crd. You have 8 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU2ARD3 CSC version: J250GOLC2ARD3 Phone version: J250GDXU2ARF2 Product code: SM-J250GZKAXTC CSC country code: PHILIPPINES CSC sales code: XTC Phone SN: R28K21PCQ3E IMEI: 354062090238371 HW version: MP0.800 RF cal date: 2018.02.13 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2018-04-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM4 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.34.6 | |
03-25-2023, 14:49 | #9 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | hello: is this possbile to unlock?? Checking Login and Password... OK Balance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting for device to become ready... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU3AUG1 CSC version: J250GXSA3AUG3 Phone version: J250GDXU3ASK1 Product code: SM-J250GZKAXSA CSC country code: Australia CSC sales code: XSA Phone SN: R28KA0QMK0B IMEI: 355738090927738 HW version: MP0.900 RF cal date: 2018.10.12 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM97 Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM51 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Server error: Could not process security data, please try again Update your firmware to latest Done with Samsung Tool PRO v.45.9 [SM-J250G,Read Codes via Server] |
03-28-2023, 07:01 | #11 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
03-28-2023, 07:24 | #12 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Tried another FIRMWARE : Waiting for device to become ready... OK Reading phone info... Model: SM-J250G Android version: 7.1.1 PDA version: J250GDXU3AUG1 CSC version: J250GTLP3AUG3 Phone version: J250GDXU3ASK1 Product code: SM-J250GZKATLP CSC country code: Australia CSC sales code: TLP Phone SN: R28KA0QMK0B IMEI: 355738090927738 HW version: MP0.900 RF cal date: 2018.10.12 Chip name: MSM8937 Modem board: MSM8917 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung diag port... detected COM97 Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM51 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Server error: Could not process security data, please try again Update your firmware to latest Done with Samsung Tool PRO v.45.9 [SM-J250G,Read Codes via Server] |
03-28-2023, 07:27 | #13 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,056 | Quote:
