Old 06-27-2018, 09:34   #31 (permalink)
Member: 120579
Thanks Meter: 186
Could you indicate a firmware with home_csc >?
Old 08-01-2018, 00:18   #32 (permalink)
Member: 175273
Thanks Meter: 68
Not work . i loose 8 hourswith this phone and still frp locked ! return the phone to the owner .
Old 08-01-2018, 08:02   #33 (permalink)
Member: 175273
Thanks Meter: 68
Two j330fn returned till now .
The Following User Says Thank You to ROMAB For This Useful Post:
Old 09-13-2018, 15:03   #34 (permalink)
Member: 403528
Sonork: 100.1646971
Thanks Meter: 26
Samsung j330fn
Originally Posted by mrfhassanlk View Post
i managed to do it after 2 weeks.
Bro download the combination file which accepted by your phone
flash the phone
then download the original firmware for that phone ( if not you cant flash boot.img error comes )
after that add BOOT, PDA , and CSC File ( use home csc) ( dont add modem cp file.
in the boot pull down menu tick only sboot.bin
in PDA pull down menu tick boot.img , recovery.img , system.img
in CSC pull down menu tick cache.img
Now flash the phone thats it frp gone.
This is working solution,l did one today and worked well.
The Following 7 Users Say Thank You to giftb31 For This Useful Post:
Old 10-16-2018, 10:35   #35 (permalink)
Member: 6999
Thanks Meter: 7
I can also confirm this works as i just did one.
thanks,
The Following User Says Thank You to judas68 For This Useful Post:
Old 10-16-2018, 10:39   #36 (permalink)
Registered User
Member: 2259770
Thanks Meter: 7
How To Remove Samsung SM-J330L Google Account Remove First On Net
Search this name Youtube
You bypass this this model j330l or j330fn
Old 10-16-2018, 10:42   #37 (permalink)
Member: 6999
Thanks Meter: 7
i just did samsung j330fn
Old 11-07-2018, 11:02   #38 (permalink)
Member: 512503
Thanks Meter: 14
flash the phone
Tested, FRP gone !!!
The Following 9 Users Say Thank You to pk4fila For This Useful Post:
Old 11-07-2018, 13:58   #39 (permalink)
Member: 1197057
Thanks Meter: 5
100% work for me
thanks
Old 11-07-2018, 13:59   #40 (permalink)
Member: 1197057
Thanks Meter: 5
100% work for me
thanks
The Following User Says Thank You to scape72 For This Useful Post:
Old 11-14-2018, 10:14   #41 (permalink)
Member: 2739988
For me also work 100% safe ang quick method!
Thanks!
Old 12-07-2018, 12:57   #42 (permalink)
Member: 1988221
Sonork: slam4neon
Thanks Meter: 22
thanx
good gob its work %100 you rocks
Old 12-07-2018, 14:13   #43 (permalink)
Member: 2643497
Thanks Meter: 6
flash full flash after reboot flash boot from combination on same security open z3x shell select g935f and reset frp adb done
The Following User Says Thank You to al22 For This Useful Post:
Old 12-09-2018, 18:41   #44 (permalink)
Member: 1296393
Sonork: ashok
Thanks Meter: 2
After 2 day west i return back
Old 12-30-2018, 15:33   #45 (permalink)
Member: 2336789
Thanks Meter: 17
Hello no need pc no need box I have remove frp without box . Here the link how
https://you tu.be/gek6NQPg3rU
Today I have fix and remove frp from Samsung J330fn and I have updated the Android to 9.0 is perfect working like charm
Z3X is not solution
The Following User Says Thank You to olger For This Useful Post:
Page generated in 0.21733 seconds with 9 queries
